Projects 34 Ford truck build a.k.a ( The Black Dahlia)
Discussion in 'The Hokey Ass Message Board' started by quandel_garage, Dec 25, 2012.
  1. Mat Thrasher
    Mat Thrasher
  2. fleetside66
    fleetside66
    Thanks for posting that dash rail lowering thing...I missed it along the line somehow. I found that to be of interest, because here in Pennsylvania, we have to have at least 7" of windshield space at the narrowest point. For example, I chopped mine 3" & the narrowest point is a tad over 8." That means, a 4" chop would be the max (at least for the 32-34 Ford trucks). So, the dash rail lowering thing would enable people desiring a more radical chop a little more leeway.
  3. quandel_garage
    quandel_garage
    Yeah i.agree good tech article there. How easy.was it to.chop the windshield frame?
  4. Not sure who you are directing the frame chop to but mine was easy. I chopped mine by removing the bottom and then cutting it on an angle.
  5. quandel_garage
    quandel_garage
    I was more interested in figuring out the contour of the frame since it.will now be longer on the bottom.sides
  6. 76cam
    76cam
    Going to be pretty sweet!!!! Love the comet also!!!!
  7. VoodooTwin
    VoodooTwin
    from Noo Yawk
    The bottom of the windshield frame should remain the same width after the chop/dash recess. No? The only mod required is to shorten the vertical legs, and of course the gl***. Maybe I'm not seeing it right though?
  8. Rocky
    Rocky
    Classified Editor
    I'm sure all I did was shorten the verticle legs when I chopped my 33. I cut it 5.5" and it was already channelled over the width of the frame. I'm 5'9" and after mounting my van 3rd seat flat on the floor, I had about 1.5-2" of space between my head and the top. I used a 49 ford dash in mine and don't remember having any problems seeing out except for those damned Kansas City traffic lights! I'd just wait 'till I saw them change color in the reflection on my chrome air cleaner.
  9. falconsprint63
    falconsprint63
    from Mayberry
  10. HELLVIS
    HELLVIS
    i like it!...keep it up!
  11. WDO40
    WDO40
    Am in going to follow along
  12. Mat Thrasher
    Mat Thrasher
    The contour doesn't change. But I think with a 7" chop you're going to have to cut it at the bottom corners and tilt the legs out. Like SPDJUNKY said how how he did his.
    I used a repro aluminum frame and when I tried to just cut down the height and force it wider at the top the center bottom humped way up. So I cut the bottom corners and tilted them out like I said above. Then the contour came back to the way it was supposed to be.
  13. TinShed
    TinShed
    If you don't mind me asking what did you give for the truck you started with? There are 2 on a tree line about a mile from me in about the same shape. The owner will sell them he told me to make a offer.
  14. quandel_garage
    quandel_garage
    I.had.to.cut my.A pillars and tilt them out so I'm guessing that will be the case with the windshield Also.
  15. quandel_garage
    quandel_garage
    Cut the hole for my third brake light.
  16. quandel_garage
    quandel_garage
  17. quandel_garage
    quandel_garage
  18. quandel_garage
    quandel_garage
  19. Hotrodhell35
    Hotrodhell35
  20. Kevin Lee
    Kevin Lee
    Super Moderator
    Eh, you just lost me.
  21. Hotrodhell35
    Hotrodhell35
    yea, i didnt see that coming.
  22. Grudge
    Grudge
    But I uh..is that..uh..it was gonna..did you save the little circle you cut out?
  23. itsmee
    itsmee
  24. VonKool13
    VonKool13
    Looks rad. A lot of members have commented on other threads about the dangers of not seeing brakelights on hot rods and those hot rods being hit, your work will help to minimize that possibility. I like it.
    Sent from my DROID device using the TJJ mobile app
  25. OoltewahSpeedShop
    OoltewahSpeedShop
    Oh no.... This is going down the wrong road.
  26. Hotrodhell35
    Hotrodhell35
    while its good to be safety minded, it still has to be appropriate. that third brake light is less than appropriate.
  27. quandel_garage
    quandel_garage
    Everyone is en***led to their own opinions. For a truck that is this small height wise it is more than appropriate. Any help being seen ill take. I've been hit before its no fun. As far as everything else if you don't like it to bad,my truck, my ideas, my build.
  28. VonKool13
    VonKool13
    Opinions are like a$$holes....
  29. Slag Kustom
    Slag Kustom
    how far does that light stick into the cab right where the p***engers head is going to be???
  30. quandel_garage
    quandel_garage
    Only an inch. No further than the lip of the back window on the inside.
