S10 front clip
Discussion in 'The Hokey Ass Message Board' started by Shawns49, Jan 9, 2013.
  1. Shawns49
    Shawns49
    What should an average price be for a frame or clip from an S10??????? I am looking now and dont need to LOOSE money:mad:...............Thanks Shawn
  2. gwarren007
    gwarren007
    $200-$400
    What are you putting it in?
  3. They go for around $100.00-$150.00 around here. Thats for a rolling ch***is.
  4. Shawns49
    Shawns49
  5. chaddilac
    chaddilac
    I bought a complete ext cab v6 s10 and parted it out and made over a grand extra from what I paid!!
  6. supervert
    supervert
    Around here you can get a running driving trucks for 500 all day long
  7. 40Standard
    40Standard
    from Indy
    that's the way to do it
  8. Shawns49
    Shawns49
    I wouldnt mind doing the parting out thing ,I just dont have room :(
  9. the-rodster
    the-rodster
    I paid $200 for a rolling ch***is.
    $100 for dropped spindles
    $60 for dropped springs
    All from craigslist.
    Rich
  10. Mr48chev
    Supply and demand in the area you are in is the largest factor. If you are going to get one out of a junk yard try to get one from a truck that they pulled the engine out of but still has the front end sheet metal on it in good shape to show that it hasn't been wrecked. A little more work there will save you headaches later. Actually I think you would only have to take the bumper off and unbolt the core support from the frame and then cut the frame where you wanted to cut it. I'd suggest as far back as you could and then trim to fit.
  11. Even with the front sheet metal removed, look at the front frame horns, this will tell you if it had been hit......
  12. beyond static
    beyond static
    from Louisiana
    I got one out of a pull-a-part junkyard for $250. They let me bring in a generator, so I used a sawzall to cut it off. The truck already had the engine and front sheetmetal removed, which made it an easy job. I wanted to buy a complete truck and sell the extra parts like others have done, but I didn't have the room for it.
