model a owners what column?
Discussion in 'The Hokey Ass Message Board' started by rawcjw19, Jan 9, 2013.
  1. rawcjw19
    rawcjw19
    Hello
    I was wondering what the best choice for a steering column for my 30 sedan would be? I am wanting a older junk yard.My sedan is channeled 3 1/2 and will be chopped if that makes a difference. Just curious what others are using and what years to look for, also safety. My wife will be driving it and my boy when he is older.
    Thanks and some pics would be nice.
  2. There's a guy over on the Ford Barn that sells F100 boxes that are modified to bolt onto Model A frames, it's a common update for stockers. You would have to shorten the column for a channeled car but it's not a big deal. If I'm not mistaken they're '53 - '56 boxes.
  3. Fenders
    Fenders
    You asked about a column, don't know if it helps but here's what I have:
    Steering box: 1965 Mustang
    Steering wheel, shaft and bearings: 1967 - 73 Chevy truck (?)
    Steering mast jacket: exhaust pipe
    Lower mast jacket support: Late 1931 Ford
    Re the steering shaft etc that's what I was told when I bought the complete ***embly at a flea market... I removed the mast jacket etc and just used a piece of exhaust pipe. I welded the lower end of the shaft to a Speedway Ujoint.
    See photo
  4. Bluedot
    Bluedot
    Corvair columns are small and clean - nothing but the wheel and turn signal. That's what I'm using. Space considerations at the bottom end made me go to a double U-joint into a Corvair reversed box for traditional steering.
  5. Blues65
    Blues65
    I am using a 1956 Ford F100 Steering Column connected to a GM (525) Saginaw Manual Steering Box (cross Steering).
    I built the column from parts I collected from (EBay, & MAC’s). The column is 2” diameter and the turn signals works reasonably well but the horn wire runs through the steering shaft so I had to sacrifice the horn ****on on steering wheel until I collect all the parts to convert to 59-62 column.<O:p</O:p</O:p
  6. b-bob
    b-bob
    Because i like early Ford steering wheels, i like to shorten the same column to go with it. A machinist friend can make you up a support for the bottom of the column.
  7. rawcjw19
    rawcjw19
    B- bob What year column are you talking? Pics? I am a tool maker by trade just need a direction. Thanks for all the ideas lots of good ones on here.
  8. MATACONCEPTS
    MATACONCEPTS
    try a 40's/early 50's chevy car. Ive seen those on channeled cars
  9. F-100 boxes were what we used and you can mate an early colum to them like a '40 or just use the truck colum. I like the earlier colum with the lock in them but I also like the simplicity of the truck colum, to me either one looks good. They were still using the locking colum in the '46 trucks I don't know about after that.
  10. V4F
    V4F
    from middle ca.
    chevy tilt columns are very popular for changing the column ........
  11. klifton1
    klifton1
    I have an F-1 column in my 29. Plenty of clearance and cheap.
    Klif
  12. junk yard kid
    junk yard kid
    There was a guy on here that did a tech week thread on making your own column. Looked real easy.
  13. Depends what box your going to run, my friend used a postal jeep column in his '30 with a Vega box.
