stainless steel lower rad. hose
Discussion in 'The Hokey Ass Message Board' started by jan bogert, Jan 9, 2013.
  1. jan bogert
    jan bogert
    i just installed one of these stainless steel lower radiator hose. has anyone have any experience with these? i had no other choice, because of clearence issues. and the way my outlets lined up. my worry is sealing with the clamps. anyone useing these? its from summit.
  2. Crystal Blue
    Crystal Blue
    Looks good from here:rolleyes:
    A pic or link might help :eek:
  3. Blue One
    Blue One
    from Alberta
    If you are talking about the flexible stainless hoses that have ribs and are connected on the ends with rubber hose and clamps, I would not use them.
    They are absolute garbage.
    My son had them on his 479 CI big block Pontiac engine and had 2 instances where they literally blew off under normal radiator pressure, while the engine was hot.
    Once was when he was working on the tuning of the engine, setting the timing and carb adjustment.
    The engine is a radical roller cammed engine and was not overheating, everything was working normally.
    He narrowly avoided serious burns and had mild burns on one arm.
    The second time was during the drive back on the return road after a p*** at the strip. Again, normal temp and pressure, no overheating.
    Once those hoses were removed and proper hoses installed there have been no problems.
  4. jan bogert
    jan bogert
    i don't have the linement of the outlets to use regular hoses i want to but can't. that is the ones i'm talking about.
  5. Mopar Jack
    Mopar Jack
    Ive used them on my coupe for over 15 years with no trouble...
  6. dirtybirdpunk
    dirtybirdpunk
    Been running one on the wife's 350 powered Rambler without issue for 6+ years....
  7. jan bogert
    jan bogert
    i'm hpoeing they will be alright, that they seal. seems like it went in the rubber on the radiator pretty easily. i'm keeping my fingers crossed.
  8. brigrat
    brigrat
    from Wa.St.
    As you can see they work for some but not for others. If you get to solid of a fit there will be no "give" with motor harmonic's, movement and I have seen them crack out the radiator outlets. JMO
  9. tfeverfred
    tfeverfred
    The way that's set up looks like the hose end going into the rubber is off center. Maybe it won't hurt anything, I've never used that type hose before. I'd get a smaller clamp. I'm guilty of using clamps that are too long and end up going back after a while and getting the right length. I just looks better and one less thing to cut your hand or fingers.
    What about the rubber flex hoses?
  10. jazzbum
    jazzbum
    Took the words out of my mouth. Those aren't great either, but I'd think they'd be a damned sight better than the steel.
  11. from what i can see , i think a regular rubber radiator hose could be made to fit. try Napa # 7286. you will need to trim it on both ends
    or...i would use a 90 degree rubber bend off the radiator , a 45 off the water pump and then connect them with a short piece of stainless steel tubing
  12. HoodDirty
    HoodDirty
    from Boulder
    You could have the radiator out lets relocated if that hose doesn't hold up.
  13. NEWFISHER
    NEWFISHER
    from Oregon
    +1 .
  14. saltflats
    saltflats
    from Missouri
    Maybe see if you can find some of those wire hose clamps that whould tighten down in between the ribs on the tubing.
  15. 59 brook
    59 brook
    i've had the same thing on my lower hose for 10+ yrs with no problems. i think they are mostly corrugated copper tubing chrome plated and should easily be able to handle low pressure for a long time. after all copper tubing lasts in your home plumbing for decades. the rubber connecdtors are similar to fernco couplings used in plumbing and i believe they are rated up to 15 psi . so if you run 7 or so psi cap should never be a problem either . but that does not guarantee the quality of the installation which can ruin it almost immediately
  16. jazzbum
    jazzbum
    that'll work. and actually, unlike pretty much anything else on a car, designing in a little turbulence is good when you're dealing with coolant, as long as you're not creating severe restrictions.
  17. Dane
    Dane
    from Soquel, CA
    I use them with T-Bolt clamps and have had zero problems over the years.
