whats your favorite filler primer ?
Discussion in 'The Hokey Ass Message Board' started by 31Vicky with a hemi, Jan 10, 2013.
  1. I tried some ***berland 2k 6550 and Im not liking it.
    Usually use Mar Hyde in buff but the supplier was out of it. He said the ***berland was "exactly" the same just grey.
    The ***berland is loading up my paper (mirka) and I find it to be exceptionally soft.
    Someting is wrong here- Im wondering if its just me & what I'm used to, the supply house opinion or problem with the material batch. It was mixed exactly as the tech sheet said, and shop conditions are the same. These two products are no where near the same.
  2. lippy
    lippy
    from Ks
    I use Keystone. It's Key 3 in 1. Hundred bucks a gal with the activator. Never had a problem and it sands easily. Lippy
  3. snopeks garage
    snopeks garage
    from macomb MI
  4. BISHOP
    BISHOP
  5. HOTRODPRIMER
    HOTRODPRIMER
    I don't know if it is my favorite but I have had good success with this brand in the past few years. HRP
  6. Lowrders
    Lowrders
    from DUBUQUE IA
    I gotta say pretty much anything Polyester.. Unbelievable fill, No shrinkage, sands decent. The only gripe is it stinks real bad, and is super bad to breath in- have a good respirator!
  7. Lowrders
    Lowrders
    from DUBUQUE IA
    He was asking about PRIMER, but yeah, Rage GOLD is where it's at!
  8. motobilt
    motobilt
    from okc
    3M spray polyester is great stuff for leveling pitting etc, but you need to prime bare metal with an Epoxy or similar type of primer first
  9. I'm past the poly high build stuff.
    I used upol reface, really nice stuff.
    2k urethane filler primer is what I'm looking for.
  10. X2 good stuff
    Seems to clog up my gun though, enen with a reammed out 22 tip.
  11. charleyw
    charleyw
    Clausen Z chrome for me.
  12. Anyone have a similar or different experience with ***berland 2k urethane filler primer?
  13. flthd31
    flthd31
    Kinda sounds like maybe you need a little more flash time between coats. Since you have experience with primer surfacers, you already know it's critical to allow enough time between coats of primer surfacers to allow solvents to evaporate or the coats underneath won't cure quickly and clogging paper will result.
    My favorite is PPG K36 but I've been using Nason recently to save some bucks and have had good results.
  14. Flash times were just over 5 mins / 3 coats with medium reducer 4/1/1 on the cup & via kitchen timer.
    I also let it sit for 2 days in 70* before sanding.
    I can tell no difference in top skin sanding or deeper / all dry sanding.
    So soft I flat spotted a body line with 400 paper that was clogged.
  15. Rich Wright
    Rich Wright
    I started using Nason 2K primer years ago.
    It's inexpensive and works very well. Maybe not as good as some of the really high build primers but it fills well and sands easy and the cost difference more than makes up for the reduced fill.
    Just make sure to follow instructions about flash time between coats.
  16. snopeks garage
    snopeks garage
    from macomb MI
    did you shake the can of primer before you mixed it? Did you stir for a good 30 sec after mixing?
    Hardeners will start to catalize or go bad is the tops not on tight after opening, maybe that?
  17. Fresh can and sealed hardner.
    No shaker but I ran a drill powered propeller style paint stirer in the can for about 3-5 mins until no solids were on the bottom.
    Mixed primer in cup for @ least 30 seconds let it set for as long as it took to tack rag the hood and stirred it again before pouring it into the gun.
  18. flthd31
    flthd31
    Not sure if this what you used but this ***berland tech sheet calls for 15 minutes...here's a copy and paste from it:
    2. For high build apply up to 4 or 5 wet coats allowing 15 minutes flash time between coats, for normal build or pinhole filling apply as needed.
    Also, the sheet calls for mix 4/1 - primer/activator for high build...no reducer.
    The whole sheet is here:
    http://www.***berlandproductsinc.com/uplimg/CP6550_6525.pdf
    Hope this helps.
  19. snopeks garage
    snopeks garage
    from macomb MI
    it sounds like your put on to much primer on too fast and t****d the solvents. By the time the last coat starts to skins over your first couple coats are still wet. paint and primer drys by the solvents comeing out evaporateing in to the air, inproper flash times trap those solvents not alowing the primer to dry corectly. I would remove all that primer or you might have problems when you paint it like die back or shrinking. Good luck
  20. TR Waters
    TR Waters
    from Vermont
    I do not use a filler primer. I have no favorite.
  21. Yep I shorted the flash times. Thanks that helped a lot.
    I'll take it all off. That should be fun.
    Looks like if I want 4-5 coats with 15 mins flash time and only 1 hour pot life I have some figuring and better planning to do. Or wait for the other primer.
  22. modelamotorhead
    modelamotorhead
    PPG Kondar, fills well..sands easily.
  23. TR Waters
    TR Waters
    from Vermont
    I made a general statement about these "filler" primers, and the problems so often ***ociated with them. Sorry if it upset you. I corrected my original post to answer the question at hand.
  24. 28TUDOR
    28TUDOR
    Slick Sand works great for me.
  25. captmullette
    captmullette
    <TABLE cellSpacing=0 cellPadding=0 width=560><TBODY><TR><TD style="MIN-HEIGHT: 115px; WIDTH: 150px" vAlign=top align=middle>[​IMG] </TD><TD style="PADDING-BOTTOM: 0px; MIN-HEIGHT: 115px; PADDING-LEFT: 10px; WIDTH: 330px; PADDING-RIGHT: 10px; COLOR: #666; PADDING-TOP: 10px" vAlign=top>5 Star MA** FILL 2K High Build Urethane Primer Quart KIT 5453 & 5457 BUFF
    Sold by KustomPainting
    Condition: new
    <TABLE border=0 cellSpacing=4 cellPadding=0><TBODY><TR><TD style="VERTICAL-ALIGN: top"></TD><TD>[​IMG] </TD><TD>[​IMG] </TD><TD>[​IMG] </TD></TR></TBODY></TABLE>
    </TD><TD style="PADDING-BOTTOM: 0px; MIN-HEIGHT: 115px; PADDING-LEFT: 0px; WIDTH: 80px; PADDING-RIGHT: 0px; FONT: 14px Arial, san-serif; PADDING-TOP: 10px" vAlign=top align=right>$27.89</TD></TR></TBODY></TABLE>just ordered this off amazon.com havent used it yet, thats why i only ordered a small amount,
  26. I do not use a high build primer, but if I did I would use Southern Polyureathane's, all their other products are great and more reasonably priced than most.
  27. Terraizer
    Terraizer
    Clausen's Z-Chrome for me, it builds nice and sands real easy.
  28. jophus
    jophus
    Upol is affordable (less than $100) a gallon. Fills really well. However, you need at least a 1.8 tip or larger to shoot. Otherwise, you end up reducing the hell out of it and it doesn't fill as well.
  29. Kona Cruisers
    Kona Cruisers
    depends on th ebudget you have to work to.
    1. k36
    2. Slick Sand
    3. Nason.
  30. I talked to Nick at ***berland tech line. Told him I shorted my flash times .
    He knew and told me exactly what my paper was doing.
    Said that if I were to break the surface 100% and put a lamp on it I should be able to smell the solvents and in about 1 hr to 90 mins carry on as normal.
    That worked perfectly .
    Thanks guys.
    PS what are you guys paying for the K36? I about **** when I was quoted a price
