Projects Wood beds done right
Discussion in 'The Hokey Ass Message Board' started by cowboy_101, Jan 12, 2013.
  1. cowboy_101
    cowboy_101
    from Lavon, TX
    anybody out there have any good pictures or instructions with dimentions for installing a wood bed on a stepside? i've got a few different options and am looking for more ideas. just need to make sure all my parts are there. ie...
    8 boards,
    4 @ 5 1/4"
    4 @ 7"
    3 cross pieces
    any detailed pics would be fantastic.
  2. e-tek
    e-tek
    from SK, Canada
  3. TomWar
    TomWar
    My 58 (Sold)with Cherry and ash Bed.
  4. ChucksCrib
    ChucksCrib
    from Uranus
    these guys are a wealth of information.
    http://www.mar-k.com/
    I've purchased from them in the past. The holes drilled into the cross sills dictate the widths of the boards needed......and they've changed widths every few years with the Chevy/GMC trucks.
  5. VoodooTwin
    VoodooTwin
    from Noo Yawk
  6. mastadon
    mastadon
    Hi,I'm not sure what type of finish you want on your wood but I will tell you my experience with our two trucks,keep in mind that both live out side in the brutal Texas heat.The 1st try was with my wife's 55 and I painted the wood with exterior grade oil based paint and within a year it was fading and peeling.then when I built my 51 I went with a high dollor marine grade clear varnish.In 6 months it was peeling.Removed boards and stripped off varnish.Painted boards with POR15 sanding between coats then sprayed on single stage acrylic urethane gloss black.Still looks like new after 2 years.I just finished my wife's truck 2 weeks ago but did it in white.Now if you want the wood to be natural I would spray it with automotive clear.A little long winded my my 2 cents.
  7. I used the same folks, worked out real well. Used HOK black and several coats of Southern Polyureathane's Universal clear w/UV protecter for finish.
      360.8 KB
  8. bonez
    bonez
    from Slow lane
    ^^^^ Those black boards look the business.
  9. Moonequipt13
    Moonequipt13
    If you want black without paint use ironwood...it actually clanks like iron when you knock on it
