i need help reverse flowing.a nailhead!!
Discussion in 'The Hokey Ass Message Board' started by quandel_garage, Jan 7, 2013.
  1. quandel_garage
    quandel_garage
    Hi I'm looking for any information or literature on reverse flowing a nail head or any v8s. I've did a search but no tech articles surfaced. Thanks guys!
  2. quandel_garage
    quandel_garage
    Thanks. Anyone else ??
  3. Well, years ago Smokey Yunick developed and built reverse-flow system for some of his Trans-Am race cars – but then again Smokey had pretty much unlimited resources. Several independent engineer / engine builders have toyed with reverse cooling but as you already know the LT1 was the first “m***-produced” engine with reverse-flow cooling.
    There are differing opinions on the effectiveness of reverse-flow cooling. It would appear to be better than standard-flow systems but it certainly requires additional engineering to make it work properly. In a “standard flow” engine the coolant is typically boiling somewhere in the engine – more than likely in the coolant p***ages within the cylinder head as this is the hottest point the “coolant” comes into contact with. The temperature of the interior engine walls surrounding the combustion chambers are far above the boiling point of any known coolant. The coolant directly in contact with the back-side of the combustion chambers, particularly near the spark plugs and exhaust valve seats, turns to vapor. This forms a turbulent natural convection where the vapor forms bubbles that collide causing a condition known as “nucleate boiling”. This condition is not harmful as long as the vapors are continually moving and not allowed to ac***ulate (like when an engine runs cry – very bad things happen). Under normal engine operating conditions, the coolant flow rate is sufficient to move the vapors along while continuing to flood the area with a steady stream of liquid coolant. As the liquid hits the vapors, any of the above mentioned “bubbles” that may have formed condense back into the coolant stream.
    If a steam pocket forms, the vaporized coolant may prevent the flow of the coolant to that area of the water p***age and a hot spot will develop on the inside of the chamber. This condition can cause detonation and potentially lead to engine failure. Vaporized coolant cannot transfer heat as efficiently as liquid coolant so in essence, it acts as an insulator, allowing the temperature to go into the stratosphere.
    In a reverse-flow system, the coolant flow not strong enough to expel the vapor from the cylinder heads down through the engine block and out to the radiator. The vapor, instead, will remain trapped around the cylinder head, where it will become super heated and in all likelihood - melts your engine.
    GM came up with a solution to this problem. They vented the cylinder heads where coolant vapors would normally collect. On the Gen II engines, these vents are on the rear side of the cylinder heads. Steam and trace amounts of liquid coolant escape through a banjo fitting into a tube that goes into the coolant overflow reservoir. The opening of the banjo is small enough to limit liquid coolant from flowing through it, but allows steam to easily p***. As the steam travels through the little hole in the banjo fitting, the pressure drop and it condense to a liquid state as it returns to the overflow reservoir.
    So to “convert” from standard to reverse flow cooling, you’ll have to have the steam holes and a means to regulate / restrict the p***age of steam vapor and fluids. You’d also need to capture and return to the cooling system.
  4. belair
    belair
    Are you talking about coolant or fuel?
  5. quandel_garage
    quandel_garage
  6. quandel_garage
    quandel_garage
  7. wbrw32
    wbrw32
    You will need to start with a reverse ground camshaft..BUT,,,WHY????? Whats your intent?
  8. belair
    belair
    MAYBE Tommy Ivo did one?
  9. the-rodster
    the-rodster
    Didn't I just see a pic of a reverse induction nailhead on here the other day?
    Or was it something else?
    Rich
  10. 24riverview
    24riverview
    This one?
  11. the-rodster
    the-rodster
  12. cakes
    cakes
    ^^^^ that FED is WAAAAAAAAAAAAAAY cool
  13. Beau
    Beau
    Just because it can be done...
  14. quandel_garage
    quandel_garage
    Exactly. I want to get out of my comfort zone. This sounds like a good jump.
  15. DualQuad55
    DualQuad55
    from NH
    Likely there will be very little actual info. A few have tried to make a reverse flow engine work typically using a supercharger to force air through the smaller exhaust ports/valves and use the larger intake ports/valves for the exhaust. However, no one has had enough sucess with this (or any notable sucess at all) to make it a common practice.
    I can tell you for a fact that the biggest increase in a Nailheads performance is actually getting more air into it, not the exhaust like commonly thought. Not to say you should neglect port work, but when more air is allowed in the Nailhead makes more power than if more exhaust is let out-all other things being equal.
    If you decide to use the reverse flow on the Nailhead, supercharging is the best bet as the exhaust ports have a bad short turn radius which would not likely do well if just using engine vacuum to induct air and fuel.
    But if power is what you want not just a freakshow, I would set the supercharger up conventionally for induction weather it is front mount or top mounted.
  16. deto
    deto
    bad *** mofo!
  17. Beau
    Beau
    ...doesn't mean you should! :D
    If you have to ask how, you probably can't. But it's still a neat idea.
  18. quandel_garage
    quandel_garage
    Thats a poor at***ude. If i thought like that i never would have learned or accomplished anything.
  19. redlinetoys
    redlinetoys
    from Midwest
  20. 55willys
    55willys
    You will have to swap the intake and exhaust lobes on the cam. In order to do this You will need an unground cam blank. As mentioned earlier to get any benefit from this you will have to supercharge it. I am doing the same thing with a flathead V8 and a front drive blower. Check out my thread front drive blown reverse flow.
  21. Jkustom
    Jkustom
    What is the pay off for doing this to an engine? What are the reasons it would be desirable? I've never really learned much on this particular subject.
  22. LSR 2909
    LSR 2909
    from Colorado
    People, (Craiger, Bill Kenz, and others I'm sure) did reverse cam MODEL A'S because there are four exhaust and only two intake ports, effectively doubling their fuel intake.
  23. propwash
    propwash
    from Las Vegas
    While it is apparently not what the OP was looking for, I would like to thank you for this explanation on the cooling system. Most thorough I've ever read.
  24. quandel_garage
    quandel_garage
    Thanks for the information so far guys. Much appreciated
  25. I read through the T bucket page a little. Apparently, he made the "reversed" cam by turning the lobes round and then metal spraying the blank back up to create new lobes in the right area. Wow, hot rodding at it's finest.
  26. Dapostman
    Dapostman
    Besides the cam, Just basic plumbing. Make an intake and exhaust, but use the opposite gaskets for patterns.
  27. toxic waste
    toxic waste
    from Iowa
  28. 35chevycoupe
    35chevycoupe
    from Visalia CA
    How about disecting a hilborn fuel injection and fitting to the sides of the motor, That would look cool
