Limework Column & Drop
Discussion in 'The Hokey Ass Message Board' started by Jim P, Jan 13, 2013.
  1. Jim P
    Jim P
    from Tyler, TX
    I recently purchased an 1 1/2" dia column from Limeworks and one of their 4" -'32 drops to fit the column. I went with unfinished column with plans to paint. This ****er is tight. I can tap the drop on with a rubber hammer but it's way to tight to install once I get it all painted (scratch the paint). Everyone that has gone this route how did yours fit? Is there a trick I am missing to slide this on the column easier without jacking the paint up?
    Thanks
    Jim
  2. isn't there a set screw on the bottom to clamp it tight?
  3. HOTRODPRIMER
    HOTRODPRIMER
    Man,I hope it ain't that simple or he's gonna be doing this. [​IMG] HRP
  4. unkledaddy
    unkledaddy
    Can you not ream the hole in the drop out a bit by some means?
  5. Dennis D
    Dennis D
    Insert the clamp bolt from the threaded side and put a small washer in the split to keep the bolt from going into the non-threaded hole. Gently tighten until the clamp opens up enough to slide on the column. Worked on mine that I got from them. Dennis D
  6. Jim P
    Jim P
    from Tyler, TX
    I wish it was that easy. ;)
  7. Jim P
    Jim P
    from Tyler, TX
    I'll give it a shot. Thanks for the tip.
    Jim
  8. so there is a clamp screw on the bottom then? the one i used did
  9. kool32
    kool32
    from Kentucky
    I used a screw driver to spread the clamping end and put a coin in the keep the spread. Worked for me...........let the flaming begin
  10. Jim P
    Jim P
    from Tyler, TX
    I ran the screw against a putty s****er and worked like a charm. Thanks for the help guys. Sometimes it's best to take a step back and there's a solution. I knew you guys would have a fix.
    Jim
  11. Limey Steve
    Limey Steve
    Alliance Vendor
    from Whittier
    I just found this old link, we now make the column drop a little larger so it slips up the column better , I'm back on quality control with a local machine shop in Whittier.
    Thanks for buying & being patient with our parts :)
    Cheers
