New here with a 1960 F100 soon to be bagged!
Discussion in 'The Hokey Ass Message Board' started by Willie60, Jan 11, 2013.
  1. Willie60
    Willie60
    from San Jose
    Hey guys I'm new here.
    I just picked up a 1960 Ford f100 truck is running very clean body i picked up in Turlock Ca and drove her home. I was looking all over for a 59 Fleet side Chevy when i came up on a picture of a 1959 ford i fell in love with how it looked like a BOX
    I'm going to start a build thread on here some ware just don't know what i put under!
    I have a lot of plans for the truck i just orderd the Front end from FATMAN mustang 2 front im going to bag the truck and i want to put some white walls on it.
    I also orderd the rear from a shop called gambino kustoms called the Tail dragger
    I should start everything this weekend and hopping it will be done in 3 months
  2. Blue One
    Blue One
    from Alberta
    I don't think you will find much enthusiasm for bagged trucks here, but I could be wrong :)
  3. pdunn10
    pdunn10
    don't let people talk you out of the way you want your truck to sit. bags are a good way to have a good ride and adjustable ride height. Research your valves and bags before you start. you should not be talked into running only four valves, go with eight and you will be way happier. Way less body roll and more adjustability.
  4. 53olds
    53olds
    Gonna be pretty sweet, would look killer with a chrome grille and white roof.
  5. Blake84
    Blake84
    make this your build thread! bags are not for everyone but thats why its YOUR truck so do what YOU want.
    people say air bags are not traditional however they are def oldschool
    "The first practical air suspension was developed by Firestone in 1933 for an experimental car called the Stout-Scarab. This was a rear-engined vehicle that used four rubberized bellows in place of conventional springs. Air was supplied by small compressors attached to each bellow."
    cant wait to see the progress
  6. Blake84
    Blake84
    also i have the gambino tail draggin kit in mine and i love it but it is set up to bag ontop of the axle which will require you having the large step notch like mine and loosing alot of the bed of your truck like mine. some people use "trailing arms" and you can bag those and get low without sacraficing the amount of space in the bed of your truck.
  7. Willie60
    Willie60
    from San Jose
    To day i just picked up the Taildragger from Gambino him self i got all the parts and he is having the bags droped shipped to my door! I went with the Slam bags!
    I will keep you guys updated
    And a big THANK YOU TO Blake!!
    For all your help so far!
    Ill post some pictures of the kit tonight!
  8. Willie60
    Willie60
    from San Jose
    I really like the White roof i think im going to do that!!!
  9. Willie60
    Willie60
    from San Jose
    YA I THINK YOUR WRONG ON THIS ONE!!
    I seen a lot of bagged trucks on this site and a lot of them get mad love!!
    But hey thanks for your thoughts!!!
  10. mattrod68
    mattrod68
    cool truck, but im biased. needs some chrome!
    matt
  11. matthew mcglothin
    matthew mcglothin
    Very cool truck! Had a 60 ford before my 58 apache. I miss the 60 very , very much! "Airride" as I like to call it is ok to me, I like air and static drops and had both. They have there pros and cons.
  12. Blue One
    Blue One
    from Alberta
    Well being wrong is ok, I do like your truck. Keep safety in mind and make the build fun and practical and in the end you will enjoy the truck a lot more.
    Good build practices, quality work and components and airbag system is the way to go.
  13. willowbilly3
    willowbilly3
    from Sturgis
    Much better cab than the 59 Chevy, good choice. Looks like a nice straight old truck. Not too crazy about the smurf blue front end tho.
  14. Willie60
    Willie60
    from San Jose
    Hey Guys,
    So here is a little start i did over the weekend took off the bed and was getting everything ready for the welds.
    My buddy is coming over next weekend to weld up everything
    We also put together a PHOTO SHOP of my truck and how it can look and so on!
    I know its not going to be this low but its just a idea!
  15. pdunn10
    pdunn10
    you should do a photo shop with the door top being blue and the pillar in front of the wing window blue too. so just the top. just a thought
    and keep the badge looks right
  16. pdunn10
    pdunn10
    that bike is sick
  17. HELLVIS
    HELLVIS
    "from a shop called Gambinos"
  18. hershambob
    hershambob
    willie i just picked up a 60 temecula,just waiting for it to land in england,it wont get bags,maybe a jag clip and lower the rear nostalgia sids way
  19. Blake84
    Blake84
    love the white top and blue. so just a heads up some issues i ran into when bagging mine to think about. i have to move the wheel wells up. be carful because when he tack welds them it will burn through to the outisde skin of the truck and ruin your paint. also tire size is very important when trying to lay frame unless you plan on cutting fender wells out in the engine compartment. also tires im running 8.20x15 bias plys are taller than the height of the bed when laying frame so i actually would not be able to lay frame with my tires or i would have to remove wheel wheels and fender wells. also you will need to move fuel tank (if still in cab) and notch the cab or get a 2 piece drive shaft when trying to lay it on the ground....at least the way mine is set up i know some people have done it without. just trying to give you heads up so you can plan around what my issues were
    also i would suggest 2 air tanks and 2 compressors otherwise you will be pissed off how long you are waiting for tanks to fill up and how little air you have.
    and get an extra battery and a battery isolater to prevent dead batteries from the compressors. just my suggestions
    heres tubs moved up
  20. Willie60
    Willie60
    from San Jose
    Im planing out cutting fender walls out! I dont really care if it lays frame i dont want to remove gas tank.
    I just want it to be layed out! Like yours lol
  21. Crashhead
    Crashhead
    Good luck with the truck man. I've always dug em as kustoms, or g***ers..Built a 60 G***er years ago to get to Viva..They're fun trucks. Keep it up!
  22. Willie60
    Willie60
    from San Jose
    Did you mount Shocks? and also do i cut out the crossmember where my stock shocks are?
  23. Blake84
    Blake84
    here is where my shocks are mounted
    to the axle and up to the cross brace bar of the notch
  24. Blake84
    Blake84
  25. Willie60
    Willie60
    from San Jose
    Thats funny they took down the pictures of my harley!!
  26. Blake84
    Blake84
    they are pretty strict around here. i was just looking at the photoshops and i like the black gloss accents instead of chrome....its looks pretty cool. at the mooneyes xmas show a guy had a 56 f100 bagged and the entire truck was flat black and everything that would be chrome was high gloss black and i thought it looked pretty cool.....different but cool.
  27. Crashhead
    Crashhead
    A three inch top chop would be sweet on it!
  28. 53olds
    53olds
    Here's some inspiration~
  29. bonez
    bonez
    from Slow lane
    If you run 14" with 520s or 175/70/14s if you want radials, you might do away with rising the wheel tubs.
    Them things look great layed out.
    Oh, RUN SHOCKS! Dont even think about not runnin them. Its a vital part of your suspension, no matter how many guys will say you can do without them.
  30. Willie60
    Willie60
    from San Jose
    Thanks to Everyone for all the Love on the Truck! Man let me tell you how i wish it was all done tomorrow!!
