Projects Belly tank jig
Discussion in 'The Hokey Ass Message Board' started by hotrodderhaag, Jan 13, 2013.
  1. hotrodderhaag
    hotrodderhaag
    I have researched alot about belly tanks on here. I am interested in hand forming my own tank. Does anyone have pics of jigs or skeletons used for this ? I have only seen one I believe. Just seeing what's out there
  2. Checkerwagon
    Checkerwagon
    The reason that belly tanks are used for land speed racing is because of their smooth aerodynamic shape. To use an existing bellytank, you have to make your drive-train and ch***is fit within the tank. If you want to build an accurate belly tank to fit on a historically significant aircraft, then you need measurements.
    If you are building a belly tank/lakester, the dimensions of the shell are somewhat flexible.
    Tell us what you want to build, it will be easier to answer your question.
    All the best,
    Dale
    Cleveland OH
  3. hotrodderhaag
    hotrodderhaag
    To be perfectly honest I wanna build a tank that will probably never leave my garage . I'm not gonna race it anywhere . Belly tanks have what got me so interested in salt flat racing and custom cars.. I'm not looking for something dimensionally perfect or one that p***es race requirements .. Just one to mess with and build a car
    ratty_aussie likes this.
  4. Checkerwagon
    Checkerwagon
    "To be perfectly honest I wanna build a tank that will probably never leave my garage . I'm not gonna race it anywhere"
    I live by the rule of "perfectly honest". Ok, that makes life a lot easier. If you want to build a belly tank, the dimensions and shape are all yours. Next question, are you going to build the shell of aluminum or fiber gl***? (makes a difference for the mold/buck)
  5. hotrodderhaag
    hotrodderhaag
    I thought about gl*** but I have no clue even how to attempt a mold.. I thought about 20 gauge steel. I only have a dc tig welder so it would make it easier to fab out of steel.
  6. hotrodderhaag
    hotrodderhaag
    This tank will be one that sits in the corner and gets talked about and fired up and that's really about it. Maybe throw it inu enclosed trailer and take it a few places
  7. rough dimensions...find and engine, front and rear axles and start fabricating. With fiberglas you will have to make a mold or buck.
    some use large foam blocks and cut them down to the proper shape then coat them with mat and resin. Working with steel will take some skill and a wood form for the proper shape. Aluminum may be easier to work with. Your skill level will dictate what material to use.
  8. I like what you want to do here. I was lead to believe that repro tanks are available in gl***. Best of luck with this ,cool !! JW :)
  9. firingorder1
    firingorder1
    I seem too remember a place in Florida that makes gl*** tanks. If you look around you'll see tanks for sale. Check the for sale forum at landracing.com and you might find one. Landracng also has a wanted forum. Finding one would be a damn sight easier than trying to build one.
  10. hotrodderhaag
    hotrodderhaag
    You can indeed buy repro gl*** belly tanks ... There pricey and its not built by me
  11. frenchie
    frenchie
    check out metalmeet.com, Ron Lile just finished a belly tank and there is info on shaping the metal to do your own.
  12. b-bop
    b-bop
    You can get a gl*** tank here
    http://www.cl***gl***performance.com/P-38%20Belly.html
    Dont know anything about the company other than looking at the website and thinking some day.....some day :)
  13. firingorder1
    firingorder1
    There's something I can understand. The bodywork on my LSR sidecar is fibergl***. My neighbor is very talented with aluminum and offered to make me a body in aluminum. I turned him down because "its not built by me". If you have the equipment and the talent go at it! And the best of luck.
  14. SJR
    SJR
    I make fibergl*** molds and parts, if theres enuf interest I would do a run
  15. llewellyn
    llewellyn
    If you were to go onto allshops.org or metalmeet.com i think there is a realy good build thread on there for making a belly tank. Mite be worth a read.
    Hope it helps
    Llewellyn
  16. sailingadventure
    sailingadventure
    DSC00152_edited (1024x768).jpg Partial Body.jpg Pictures of Buck for bonneville car.jpg Here`s the one I built. It`s 13'6" X 42". After I was finished with it I didn`t want to throw it away, so I hung it over the spray booth.
  17. hotrodderhaag
    hotrodderhaag
    Dont know anything about the company other than looking at the website and thinking some day.....some day :)[/QUOTE] some day some day is my thought too so im not putting it off anymore :)
    thanks im gonna try to make a hand formed tank. i think it will be nice.. even if its just a tank sitting in the garage.. thats enough of a conversation piece for when the guys stop in...
    lot of guys i have read would like one, but 900-1200 is a litte high for one in my opinion. just because i have seen fibergalsss products of that size and that simple of a design for less.
    do you have any information on your build?
  18. sailingadventure
    sailingadventure
    do you have any information on your build?[/QUOTE]
    Go to my website for more information about the build.
    www.mccainautomotive.com
  19. 36tbird
    36tbird
    Wow, I gotta get that 18" one and build a mock up!
  20. hotrodderhaag
    hotrodderhaag
    looks like i may just **** it up and buy a gl*** one. i called scottzrods in ohio, they dont make them, so far i only found one company that makes a gl*** tank. and thats cl***g***.
    i really wanted a metal tank to make it more real.
  21. mika112
    mika112
  22. Talk to Elmo Rodge here on the HAMB, he makes gl*** tanks with Jack Kellys old molds.
  23. 37gmc
    37gmc
    from upstate ny
    i have two , i would sell one
  24. hotrodderhaag
    hotrodderhaag
    Please message me with details.
  25. I dig what you are doing here,I thought about doing something similar years ago. JW
  26. hotrodderhaag
    hotrodderhaag
    thanks. im working on drawings in auto cad getting a ch***is lay out and alot of small parts fabed up like break and clutch petal ***embly.. with autocad and a high def plasma table.. i make just about everything
  27. Ok now im thinking again of building one,well why not,i have a 26T that was at Bonneville in 1950. I also have Willys cars so a hot Willys 4,mmmmmmmm just need to finish a couple of cars then well why the heck not !!!!!!! JW :)
  28. hotrodderhaag
    hotrodderhaag
    my thoughs on the belly tank are, its not like it is going to be road legal, so i mise well jsut start slowly putting one together... instead of rushing my *** of so i can DRIVE it in the spring... i have the room to have a tank sitting on stands and not have to keep moving it around. so thats the plan.hopefully next weekend ill be heading to pick up the tank im buying.
    not sure weather to throw the flat head V8 in it or put that in my model a and then pull the banger and put it in the tank.. hmmmmm....decisions decisions,
  29. bobby_Socks
    bobby_Socks
    from ǑǃƕǑ
  30. hotrodderhaag
    hotrodderhaag
