New KING CHASSIS dragster build
Discussion in 'The Hokey Ass Message Board' started by ChassisResearchKid, Apr 15, 2011.
  1. dreracecar
    dreracecar
    from so-cal
    ET III's 16 x 10 w/ 3.5 backspace around $750pr (new)
  2. ChassisResearchKid
    ChassisResearchKid
    from Michigan
    Thanks Bruce, that's kinda what I was looking for.
  3. dorrisdormouse
    dorrisdormouse
    from UK
    Man, I really love that body. I only want a short body for my new blown alky build, but that one looks way cool... Did I see mention that these bodies might be available for sale in the future?
    Thanks
    Dave Nelson
    www.jdn-racing.co.uk
  4. ChassisResearchKid
    ChassisResearchKid
    from Michigan
    Dorrisdormouse, Harry has this body for sale now.
  5. Royalshifter
    Royalshifter
    Moderator
    Goose bumps before turkey day....killer rail.
  6. ChassisResearchKid
    ChassisResearchKid
    from Michigan
    Al Bergler hooked me up with some zoomies he had laying around the shop for mock up. Now I have to build a set for myself.
  7. ChassisResearchKid
    ChassisResearchKid
    from Michigan
    Zoomie pic's
  8. Mattbee
    Mattbee
    Those headers look awesome! Now they just need a little bit of heat in them!
  9. voxnut
    voxnut
    from sacramento
    This is really looking great! Just curious, are you doing zoomies so you can swap back and forth? I actually prefer the weedburners, but probably because you just don't see them on dragsters that make p***es today, and the Chrysler totally lends itself to good looking weedburners. Something that's considerably harder to achive on my little injected Chevy.
  10. swade41
    swade41
    from Buffalo,NY
    nice job on those "spiffy"
  11. afaulk
    afaulk
    Dude, your dragster is looking good! I like the weed burners too, but then again it may be a good thing to see what is coming out of the pipes when making a p***.:D Have fun.
  12. ChassisResearchKid
    ChassisResearchKid
    from Michigan
    Updates are slow because I've been working on the car:). So I was able to get the steering arms bent polished and the edges rounded, weld bungs welded and metal finished, steering support made and welded, brake handle mounted and the master cylinder mount made and tached in place. Riceman and I made a deal together on a Lenco reverser,thanks Roger. I'm sure i'm forgeting something. Yep, I also got the front motor mount plates made. Like I always say, everything is subject to change.
  13. KING CHASSIS
    KING CHASSIS
    Yeah Todd!!!! Lookin Good!!!
  14. ftroop
    ftroop
    from Detroit
    Um the reverser is upside down
  15. snaptwo
    snaptwo
    Very nice work !Almost too nice according to one of CRs original welders , he stated that the bends are too nice , almost like they were mandrel bent, Scotty Fenn used a press bender because he felt the mandrel left a thin wall on the outside of the bend , at least that was Scottys theory.
  16. dragsled
    dragsled
    from Panama IA
    Looks Great Todd, Tim Jones
  17. rd martin
    rd martin
    from indiana
    lookin good todd!
  18. ChassisResearchKid
    ChassisResearchKid
    from Michigan
    ?????????.....How is this even close to a Ch***is Research car?
  19. ftroop
    ftroop
    from Detroit
    Because your the Ch***is Research Kid!
  20. GOATROPER02
    GOATROPER02
    from OHIO
    Ooops!
  21. ftroop
    ftroop
    from Detroit
    Tony, after I looked at the picture again, I realized the reverser is in right......the ch***is is upside down:D
  22. GOATROPER02
    GOATROPER02
    from OHIO
    LMOA.....Poor Todd ....Always a wipping post.
    Seriously Todd your ride is gonna be bad***!! Hope to see you in Detroit!!
  23. Kerry
    Kerry
  24. ChassisResearchKid
    ChassisResearchKid
    from Michigan
    Never seen a reverser not work mounted like that. Backward is backward regaurdless of how it's mounted.
  25. THE-SYNDICATE
    THE-SYNDICATE
  26. dreracecar
    dreracecar
    from so-cal
    A lot of racers turned them around because they all tend to leak around the shifter , getting the fork pivot high, keeps it above the oil.
    Does the reverser have a neutral in it? If not it would be wise to have LENCO go thru it, also depending how used it is somtimes the "DOGS" get worn and tend to ramp, this will push it out and cause problems with the snap rings inside. Slot the shaft and have it drop down into the support mount as a lock.
  27. hueyguns
    hueyguns
    from pa
    This is progressing very nicely. Excellent craftsmanship to all involved. What can you tell me about the scoop and injection unit? I have seen them in the oldie pictures. Are they being recast by anybody? Damn nice work!
  28. ChassisResearchKid
    ChassisResearchKid
    from Michigan
    The injection unit is a new old stock Hilborn, short 4 port. The scoop was is hand formed aluminum, made by Randy Richey.
  29. ChassisResearchKid
    ChassisResearchKid
    from Michigan
    The reverser came from a friend and is damn near new, I did flip it over, bend the lever and am in the prosess of building the lever and lock out for it. Thanks for the info Bruce.
  30. riceman
    riceman
