TECH: How to make a 4 door cool! OR...Shoebox Ford 2 Door Conversion!
Discussion in 'The Hokey Ass Message Board' started by ClutchDumpinDan, Nov 19, 2011.
  1. dogpatch customs
    dogpatch customs
    from ohio
    wow just wow. awesome work, thank you for taking the time to step by step this.
    i am getting into this very thing on a 53. and your build will be great help.
    anyone know exactly how much longer the two door, front doors are compaired to the four door, front doors?
    thanks again!
    george
  2. kscarguy
    kscarguy
    You missed your "dare to be different" opportunity, with your mad skills, you could have closed off the fronts and left the back doors...! (Just kidding) really, it looks fantastic.
  3. Nads
    Nads
    from Hypocrisy
    Beautiful work, most of the two door conversions I've seen have been pretty dismal, yours is top notch.
    kidcampbell71 likes this.
  4. DJM
    DJM
    Straight posts it is. great job. this car will be the finest custom in the Old Dominion, and Dan is becoming one of if not the best buider in the region.
  5. n847
    n847
    Holy ****...Your a beast!
  6. Blake84
    Blake84
    Any updates. What's the status of this car. Just read entire thread and I want to see the completed ride. Great work
  7. fordman1
    fordman1
    Any updates? I also am curious how it is turning out!
  8. ClutchDumpinDan
    ClutchDumpinDan
    Funny you should ask! I actually managed to sneak in a day or two on it while waiting for parts to arrive for customer projects. Update tonight! Maybe tomorrow....hopefully tonight...
  9. ClutchDumpinDan
    ClutchDumpinDan
    I've got a birthday coming up (****!) which reminded me of my self imposed deadline to get this project finished...I want to drive it by the time I turn 50, so I better get to work.
    I'm in the final stage of finishing up a customer car and apparently a new fuel pump for a '55 Plymouth is 4 days from anywhere so it left me with a little free time.
    Now, where did I leave off? Ah yes, chopping the piece out of the roof and sliding it back to make the b-pillar straight. After much aligning, eyeballing, mocking up and measuring, the b-pillars just didn't look right when they were straight. That got me to wondering if they were straight from the factory so I snagged a few measurements off a parts car...
    Well lookie there, they're "slanted" from the factory. Only an 1/8" or so, but still leaning forward...
    More to follow...
  10. ClutchDumpinDan
    ClutchDumpinDan
    Armed with my newly found measurements I mocked up my b-pillars leaning forward 1/8". Much more betterer...
    My roof piece was now to short though...
    Didn't have any extra shoebox b-pillar roof sections laying around so I added some back on. Kind of a cool looking piece I think...and I didn't loose any fingertips in the bandsaw :D
    Weld, grind, all better..
  11. ClutchDumpinDan
    ClutchDumpinDan
    Then I got all zoned out and didn't take any pics. Here's the door top tacked on and test fitting the vent window..
    I cut the vent window frame and got it tacked together...
    Ooooh, it even works!
    Now, I've got a question for YOU! When I sanded the "chrome" off the vent window frame, I said to myself, self, "that doesn't sand off like regular chrome?" When I tack welded it, it didn't look right either.
    After a quick HAMB search it appears the vent window frames are stainless, oops! So my question is, does that vent window frame need to be relocated to the nearest trashcan? I ***umed they were chrome and after welding I'd get them re-chromed but apparently that's not so...so...what oughta I do now? Get another frame and heat/bend it to shape then re-polish?
    Ok, back to the show. Here it is all welded up and ground down nice and purdy.
    Even got the inside lined up and finished off decent...
    It needs some fine tuning to get it lined up but it's close enough for now...
    Garnish moulding chopped and tacked...
    Welded and ground. The top joint kicked my ***, kept moving around when I tacked it, finally took it off and clamped a solid rod behind it to keep it straight...
    I guess it's just as well I screwed up the vent window, I don't like the way it follows the garnish moulding, to much curve on the end. Agree? Dis-agree?
  12. ClutchDumpinDan
    ClutchDumpinDan
    Thanks! I can't wait until all the chop metal work is done :D
    Thanks guys!
    Vent windows are a must have, this here ain't no street rod! :p
    Cool, look forward to seeing some pics of your '53! Since you posted this awhile ago, do you still need door measurements? If so, let me know...
    Ooooh! Ooooh! Lambo doors :eek:
    Thanks! Hopefully the only indicators once completed will be the weld lines on the inside of the roof / quarter panel...and the VIN number...
    Haha! Best builder all right!..........................on my street.................maybe.....................
    I just want a cool Shoebox is all :)
    Ask and ye shall receive! Just don't ask often :eek:
  13. KraQer
    KraQer
    from Austin TX
    Killer job man,,,,, even better thread.
  14. J'st Wandering
    J'st Wandering
    Regarding your vent windows.
    I am doing the same right now for our Mercury. I was able to bend the stainless piece and avoided any welding. On some stainless pieces I used a little heat and it made it easier.
    The Mercury has vent windows on the back side gl***. The curve got too tight to make it without cutting and welding. For that I bought a spool of stainless wire and used the spool gun on the mig welder. I think I should be able to polish it up to look good.
    Neal
  15. Double Caddy
    Double Caddy
    from virginia
    The car is coming along great. I am diffently have to come over and see it. :D
  16. lorodz
    lorodz
  17. DJM
    DJM
    Awesomeness is being achieved
  18. ClutchDumpinDan
    ClutchDumpinDan
    Made a template of the drivers side rear window...
    Transferred it to the p***. side to make sure everything stays the same. I'm glad I did as this side was a little off, a little t******* and pushing and everything lined back up. I clecoed ( I don't think that's a word) it in place so I could have it in the same position after every test fit.
    It will also help get the rear corner in the same position as the driver side and with the same radius...
    I cut the bracing off the back side of the corner piece...
    Then stuck in the shrinker to tighten up the radius...
    That made the back side a little wavy so I put in the stretcher to flatten it out...
    Once the radius was correct I marked the cut lines on the template...
    Clecoed the template back in the window opening and marked the cut lines on the body...
    Here it is with the corner, b-pillar and roof section welded up. Still needs a fair amount of hammer/dolly work on the roof as you can see...
    While letting the welds cool on the roof and window corner, I started working on finishing off the quarter panel seam, gonna come out pretty decent I think...
    Until next time... :D
  19. ClutchDumpinDan
    ClutchDumpinDan
    Cool, thanks for the info Neal. When you get around to polishing the section you welded I'd be interested in hearing/seeing your results. My welding and polishing of stainless is fairly limited and I've heard lots of issues with getting the weld to completely disappear after polishing. I guess I'll get plenty of practice when it comes time to do the window surround stainless and side trim :eek::eek:
    Thanks! :cool:
  20. Hot Rods Ta Hell
    Hot Rods Ta Hell
    Beautiful work! You're taking the time to fine tune all your panels prior to welding.
    BTW, "Clecoed" is commonly used in aircraft building circles, which I used to do. It's considered a process step (position, drill, cleco, pull apart and deburr, reposition and clecoed in, final riveting). As in; "We'll get that panel positioned and clecoed in place."
  21. EBW
    EBW
    Love this thread !! Keep it up as I am following it religiously to do mine similar !!
  22. Green Rodz
    Green Rodz
    It'll have been a month this coming week without an update.....we're DYING here! (lol) :)
  23. falconvan
    falconvan
    from festus, Mo
    Subscribed!!!! Absolutely killer work; gotta find me some doors now.
  24. flamingokid
    flamingokid
  25. matthew mcglothin
    matthew mcglothin
  26. nitrobrother
    nitrobrother
    Yeah, two-and-a-half months are too long to wait between episodes!
  27. henry's57bbwagon
    henry's57bbwagon
    I just found this the other day and subscribed, spent the last while going through all the pages at once. GREAT JOB!!!!!!!!!!!!
  28. Nads
    Nads
    from Hypocrisy
    You try to make things the same on both sides?
    You have my utmost respect, sir!
  29. gwarren007
    gwarren007
  30. Tricky53
    Tricky53
    from Bend, OR
    Great thread. Just stumbled across it. Amazing work too!!! Maybe will get the motivation to do the same to my car! Keep up the great work!
