440 Chrysler into 57 chev
Discussion in 'The Hokey Ass Message Board' started by wade57, Jan 16, 2013.
  1. wade57
    wade57
    from BC Canada
    Hey fellas. I have a 440 Chrysler engine that I'm wanting to put in my 57. Is there a mount that will work for this???
    Tow Truck Tom likes this.
  2. GregCon
    GregCon
    from Houston
    Sure...The Umakee mount will work perfectly.
  3. Zig Zag Wanderer
    Zig Zag Wanderer
    Clay Belt likes this.
  4. kracker36
    kracker36
    Cool engine for a 57 Chevy. You may need to fab some mounts. Should not be hard to do.
  5. I love the idea of putting a Mope into that Chev!!
  6. fiveohnick2932
    fiveohnick2932
    from Napa, Ca.
    Cool idea man! Yep those mounts will have to be home made. Make sure you have the metal mounts the that bolt to the block that use the rectangular rubber pads and that way you can fab from the rubber to the Chevy crossmber.
  7. mattrod68
    mattrod68
  8. OLD HEMI
    OLD HEMI
    My buddy put a 440 in a 75 Nova, he used the brackets and mount pads from a Dodge Ram Charger (75 ) and fabricated the brackets to the frame. We had a lot of fun with it. He even took 2 sets of Chevy 400 emblems and redid them to say 440.
    Lee
    Bighead440 likes this.
  9. garvinzoom
    garvinzoom
    Make it work and post the pictures!
  10. blownhemi48
    blownhemi48
    from Bergen NY
    I seem to remember an article back in the 80's where this guy was bracket racing a Vega with a 440 in it. He was using seat belts as travel limiters on his rear suspension.
  11. kracker36
    kracker36
    Weird---noone posting on this thread has a Chevy in their avatar. hmmmmm?
  12. Mopar Jack
    Mopar Jack
    Another man that has seen the Mighty Mopar light....
  13. saltflats
    saltflats
    from Missouri
    Cool idea. Is that what you had or just want to be differant? You will probably fill bad when that guy with the big block chevy in his blows you doors off.
  14. GregCon
    GregCon
    from Houston
    Of course, you could always look at it in terms of 'why waste a good engine'?
    lemondana and Bighead440 like this.
  15. kracker36
    kracker36
    EXACTLY! ------especially since Chrysler engines have no racing history;)
  16. oldschoolracer
    oldschoolracer
    from pa.
    Being a mopar guy go for it.
  17. bobby_Socks
    bobby_Socks
    from ǑǃƕǑ
    This also could go the other way
    You will probably fill good when that guy with the big block chevy in his 57 Chevy gets his doors blown off by your 57 with the Chrysler 440.
    Just sayin
  18. Brad54
    Brad54
    from Atl Ga
    I've got a '57 Chevy wagon, and a '56 150 sedan...
    This is a VERY cool idea! Definitely put the 440 in it.
    As others have said, you're on your own for front engine mounts.
    There are plenty of trans cross member kits available for '55-'57 Chevys. You'll have to modify and tweak it a bit for the Mopar trans, but that's okay.
    What are you going to run for an intake?
    -Brad
  19. I have a 55 chevy and a hemi plymouth project, so I have interest in both sides of this. Good motor, good car. Good combo?? The car doesn't care. I don't care. But don't expect much acceptance at thee local cruise nite.
    zzford likes this.
  20. rc57
    rc57
    Cool idea, make sure to consider front x-member sump clearance before you dive in.
    Good luck. pics as you progress please
  21. kracker36
    kracker36
    Yea, Im sure that the guys with the 32 fords with 350's in them will really appreciate the Mopar in the tri-5. F 'em
  22. Phillips
    Phillips
    There was a Hot Rod magazine feature car in the late 70s-early 80s, 55 Chevy with a B/RB Chrysler. Pretty sure it was a Gray Baskerville article, IIRC the swap was surprisingly painless.
  23. O.Hove
    O.Hove
    from S.D.
    Go for it
    I remember the guy that put a Ford 427 in a new Corvette
  24. saltflats
    saltflats
    from Missouri
    I knew that was going to stir you guys up. Like was said check the oil pan sump location.
    I have a 66 belvedere I am going to clone into a 67 GTX and was thinking of putting a big block chevy in it. I am sure it all boil down to what I have running at that time hell could be a 430 buick who knows.
    I am not brand specific I like most all of them if thay sound good and will burn a tire.
  25. rlsteel
    rlsteel
    A friend of mine raced a 57 with a 440 called heinz 57 in Tampa worked pretty good.
    Tow Truck Tom and Clay Belt like this.
  26. willys41
    willys41
    Cool!!! should generate some conversations.
    Remember a guy having a 57 chevy with a 406 ford tri power.
  27. rockfish
    rockfish
    Please don't *******ize that car. It needs a 350 crate motor. Gotta keep a Chevy in your Chevy. :D Just kidding. I love the idea. Good luck.
  28. Snegrah
    Snegrah
    from Pacifica
    Ok...this is hilarious. I kept reading Umakee...Umakee...WTF and then AH-HA. Never seen this comment before!
  29. saltflats
    saltflats
    from Missouri
    I remember a dirt track 55 chevy with a 427 ford in it and the ford scrip painted on the fenders. Someone put the fenders on another car and repainted them and the ford kept bleeding through.
  30. Big block Mopars fit in everything. The thought has crossed my mind before of buying a chevy and putting a mopar in it, just like an art piece to express myself.;)
