carpet edging trim
Discussion in 'The Hokey Ass Message Board' started by Chryco36, Jan 18, 2013.
  1. Chryco36
    Chryco36
    What you use for carpet edging trim? Thanks
  2. HOTRODPRIMER
    HOTRODPRIMER
    When we did the wagon we just cut a strip of the material that the seats were covered in and sewed it to the carpet. HRP
  3. 325w
    325w
    What he said. Then buy some rubber floor mat rubber and sew some carpet to it. Makes your own floor mats.
  4. Chryco36
    Chryco36
    Sorry guys i posted this wrong
    I meant as in like the silver piece that goes across the rocker panel shown in his picture.Forgot what is called.
  5. wbrw32
    wbrw32
    That piece is called a "sill plate"..depends on make of car,as they are usually made for modle spacific
  6. Chryco36
    Chryco36
    Its for my 36 chevy truck
  7. you will have to check with the vintage chevy parts suppliers to see if a sill plate is available for your truck. if not , you may have to make something or adapt from something else
  8. HOTRODPRIMER
    HOTRODPRIMER
    Ah,a misnomer,,OK
    A universal sill plate can be found as close as your local hardware store,,,flat aluminum edging for carpet or as others have said it is generally available for most specific years in catalogs. HRP
  9. 29moonshine
    29moonshine
    i bought a 1/8x 3/4 " piece of alum. from lowes drilled it and counter sunk the screws then buffed it for my 35 chevy truck
  10. Rocky
    Rocky
    Classified Editor
    ...........or you can take measurements of the rocker, go to U-pull-it or U-pick-it and measure out a few 70s-80s sill plates. [pickup trucks are a good place to look] Cut one down for your applicatrion.
  11. dana barlow
    dana barlow
    from Miami Fla.
