Projects build roadster T 26/27
Discussion in 'The Hokey Ass Message Board' started by mika112, Jan 15, 2013.
  1. mika112
    mika112
    hello I present to you my project .
    My goal, make my roadster my hands and tools .
    with a maximum of pieces can recover for money .
    first excuse me for the bad english :eek:
    any mechanics from a 1929 chevy .
    manufacture of ch***is, but it is not definitive .
    for the metal rails are 4 "to 2" U-shaped .
    support gearbox chevy back in service .
    the carrier placed on the frame .
    Here the ch***is rests on hold.
    the body is currently fibergl***, but not for the future .
    the fiber body will serve me to copy in metals .
  2. mika112
    mika112
  3. 26 T Ford RPU
    26 T Ford RPU
    Hi again Mika,i liked the concept of your T last year and i see you have been busy ! I like your attention to detail on the ch***is work and 29 Chevy mechanicals are very very cool indeed. Will follow this build with interest. JW :)
  4. mika112
    mika112
    this roadster body or rpu ???
    I will decide later, I make two bodies :D
    stamping cowl reinforcements.
    it take a little time I did glean from photos on the internet and I measures the fiber shell.
    but good **** I die is what rock & roll we look at what it will give .
    reinforcements in 1.2 mm .
    Mesh Baskets in some sheet metal .
    folded edge for rigidity .
    I ***ure you it will be inside :D
  5. 26 T Ford RPU
    26 T Ford RPU
    Mika, the bodies are the same,its just the pickup bed and the trunk that makes the differance as these unbolt and can be swapped around. My RPU was a roadster and changed to a pickup sometime in its past. I like the metal work you have done looks very good. JW :)
  6. fleet-master
    fleet-master
    the 29 Chevy disc wheels are very cool !!
  7. mika112
    mika112
    reinforcements from above the cowl .
    Here we see the poor quality of fibergl*** body .
    measures and cardboard template on the hull.
    bending of metal sheets to the door jamb and the top of the dashboard.
    and bending the shrinker door pillar according to the template.
    Following another day :D
  8. stephane-rod
    stephane-rod
    from france
    Interresting project , lol
    je tefais ça aujourd'hui ;-)
  9. slackcat
    slackcat
  10. barrnone50
    barrnone50
    from texas
    This is looking very interesting!! I will be following and learning from your skill..:D George in Texas:D
  11. mika112
    mika112
    with a jig box I reproduced in the upper cowl into 2 parts.
    Here they are in one part. prepared to make 2 body
    first welding boxes, I believe that I have not finished weld [​IMG]
  12. T Hudson
    T Hudson
    Great work Mika!
  13. falcongeorge
    falcongeorge
    from BC
    X2. Interesting, I'm gonna watch this one.
  14. aojo
    aojo
    You obviously know your way around metal. Very nice work
  15. Beau
    Beau
    Whoa! Nice work!
  16. 510madmav
    510madmav
  17. 26 T Ford RPU
    26 T Ford RPU
    Great metal work ! ! Are you still making two bodies ? Cant wait to see this come together. JW :)
  18. Heo2
    Heo2
    Hi dont copy that body if you want a body that
    look like a original ford. That body is wrong in so
    many ways
    Like on your cardbord template where you have
    a-b-c on a stock body there is no turning out
    toward c. Its a even radie from top to bottom
    And i think the lower front corner on the door
    needs to come out about 2 inch
    And behind the the door the bottom of the body
    is totaly wrong and the bottom of the body is
    to straight it should have an even radi from
    firewall to behind the door
  19. mika112
    mika112
    hello
    yes I make two replica body 26/27.
    but I'm not trying to make a perfect copy of a ford.
    the greater will be the line.
    I do not have original model, I made ​​my way one can have.
    this is not the best way but it is a replica.
    What you think , hot rod or not hot rod ?
  20. 26 T Ford RPU
    26 T Ford RPU
    Mika i can picture your car finished and it screams HOT ROD,go for it man. JW :)
  21. mika112
    mika112
  22. stephane-rod
    stephane-rod
    from france
    :p not hot rod :D je déconnes ;)
  23. Iceberg460
    Iceberg460
    Looks like a cool build, can't wait to see what you do with it..
  24. h.i.
    h.i.
    from denver
    Looks great so far. Can't wait till you do the sides by the seat! subscribed.
  25. super cool! I really like the chevy wheels!
  26. mika112
    mika112
    thank you all .
  27. mika112
    mika112
    the first firewall
    I did not want to repeat too much of a model 27, I find it too big and smooth
    I like art deco so it will be this style .
    sheet metal stamping in a cardboard template .
    beginning with the place of molding for the serial number plate .
    folding the edge of the tunnel and the edge of the box cowl.
    as with of course the bead roller :D
    here is the result of gross cold few hours in the garage .
  28. 26 T Ford RPU
    26 T Ford RPU
    Thats very cool metal work Mika. Looking forward to the rest of the body taking shape. JW :)
  29. Limey Kid
    Limey Kid
    This is very, very, good work.
    Tres bien! Sorry, that's all the French I could muster!
    Cheers,
    Stewart.
  30. TomWar
    TomWar
    Very Nice Work!!
