Technical Homebuilt quickchange
Discussion in 'The Hokey Ass Message Board' started by Jethro, Sep 10, 2012.
  1. Ned_Gob
    Ned_Gob
    Gets my vote !
  2. -Brent-
    -Brent-
    So awesome. Man, you're one of the guys around here that takes on some neat projects.
  3. 55 dude
    55 dude
    keep the tech rolling!
  4. oj
    oj
    Nice work, this one keeps getting better.
  5. Jiminy
    Jiminy
    Any update?
  6. Jethro
    Jethro
    Sorry no updates. I've been getting ready for winter, finishing little "honey do" jobs before the snow flies. I'll get back to it soon.....I hope.
  7. TexasSpeed
    TexasSpeed
    from Texas
    Man.. I just got bit with the "mill bug" and seeing this back up isn't making it any easier for me.
    Can't wait to see your next updates.
    Outback likes this.
  8. 55willys
    55willys
    Thanks for the tech and pics. This should help when I build a champ style out of a 3/4 ton rear.
  9. kennkat
    kennkat
    "A bit more to add today. I machined the shaft and test fit everything again....it's going in the right direction I think."
    :eek::eek::eek: Really?? :eek::eek::eek: Ya Think so??? :):):) Hell yes it is!! :):):) Simply a "Backyard work of ART!!" ,
    In my tired ***, old as dirt opinion :D:D:D
    Outback and volvobrynk like this.
  10. b-rod10
    b-rod10
    Great thread. Ive been inspired to try this. Keep us posted
  11. b-rod10
    b-rod10
    Well I've started laying out my rear end. I have a dumb question what gears were in your banjo. & Did you reuse the old gears. / What gears are you useing in the qc
  12. Jethro
    Jethro
    I've got 3.78:1 ? gears and the change gears I have will give me about 3.5 high and a 4.1 low. I'm using original gears.
    Outback likes this.
  13. b-rod10
    b-rod10
    Right on. Just rounding up some parts. Ill have to give it a try whats it going to hurt
  14. 66tintop
    66tintop
    from Canada
    I would say that you are one very smart feller, thanks for sharing your imagination and skills,great ideas always keep me indriged, suscribed
  15. racemad55
    racemad55
    How did you do the pressure angle on your splines,15degrees ? Make 2 extra cuts in each spline? beautiful work by the way.
  16. woodbutcher
    woodbutcher
    :eek: Very nice tech article.Great fab skills.
    Good luck.Have fun.Be safe.
    Leo
  17. Jethro
    Jethro
    I made all my cuts with a carbide 5/16 2 flute end mill. I found a centerline and with the cutter @ 90 I went up half the width of the spline and made light cuts till I got the right depth then went to the other side of the shaft and did the same thing. The splines are straight . the gaps are 60 degree. I cleaned out the center with a 3/16 cutter to take down the center ridge .
    My lingo may not be correct I'm a self taught home machinist....I've ruined a lot of metal getting to here.
    Outback likes this.
  18. b-rod10
    b-rod10
    Any progress?
  19. Jethro
    Jethro
    A bit ashamed to say that I haven't accomplished anything lately. I got a new pinion bearing and pressed and torqued it into place. Other than that not much new. Still dreaming up a design for a rear cover that I like. The other one didn't float my boat.
  20. b-rod10
    b-rod10
    I've been working on my qc. Pictures in my album. Was wonder If you had any pictures of your drive yolk or pic of what you were useing or planing on useing.I'm planing on welding the coupling in to a yolk I machined to acept the coupling.
  21. King ford
    King ford
    from 08302
    To the fellow that commented on winters units having a steel ring gear backload bolt,yes the bolt is steel but there is a bronze "cap"on the end of the bolt so you don't have steel rubbing on the back of the ring gear..."Jethro ,Awsome work,are you considering selling a "kit " of parts for do at home guys?
    Outback likes this.
  22. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Thanx for bringing this back. I want to see the finished product. Hint, hint!
  23. Jethro
    Jethro
    I hear ya. i haven't given up on it, just real slow progress. I'm making up a pattern for the rear cover/housing and keep running into design issues. I've never made a foundry pattern before so I want to get it right.....and I'm slow( not challenged just taking too damn long)
    King ford......I may come up with something like that in the future , maybe my retirement job.
  24. Alger
    Alger
    from Sacto
    Hey Jethro, any updates on the quick change?
    Matt in Sacto
  25. Jethro
    Jethro
    Holy ****! it's been a year since I pushed this thing into the corner....no progress to report...where has the time gone?
  26. Deadelvis2000
    Deadelvis2000
    from Austin, TX
    Jethro,
    Thanks for showing us your work. You have inspired me to attempt my own quick change. One question....Where did you find the Air Liquide "magic" welding rods? Ive scoured the net and can't for the life of me find them. Any
    help would be greatly appreciated!!
  27. Jethro
    Jethro
    I picked it up at a welding supply place ...I was told later that it is some kind of stainless alloy but not sure what the composition is......I'm afraid I'm not much help......good luck with the QC project....keep us in the loop , let us know how it goes!
    Outback likes this.
  28. allwilly
    allwilly
    It's called missile weld...don't remember the alloy but I will try n find it n post it
    Outback likes this.
