The rake on my ride just aint right - Its *** sits up like a cat trying to find a mouse under the fridge! I think its standard ride height but the guy who owned it before me put cut front springs on - so that half looks the goods. What have HAMBers done to fix this on their rides? What's the cheapest, quickest way to get the rake right - short of concrete bags in the boot? I've got an air ride set up but dont have the skills/funds to hook it up at the moment -thanks
Those old Pontiacs had the same basic rear suspensions from '37 to 57. I've lowered all mine with 3" or sometimes 4" lowering blocks and long U-bolts.. Might need to slide some 3 degree wedges in place if you use 4" blocks....to get your pinion angle correct again.
I hate blocks. Don't use anything more then a 4incher......otherwise you'll have ALL SORTS of drive shaft issues. Mines got 6" blocks and hardly any leaf's left. Tunnel's been re-done but I'm thinking she's gonna need a slip yoke ONTOP of bags. Listen to Rocky, he's had some ***y Poncho's! **x Brandy
I have 3" blocks on mine, rear is down quite low Can't reverse up my driveway without ripping the exhaust off
Thats what I like to hear! Nothing like that steel on cement sound to signify success! Thanks everyone
Or the clipping of road deflectors as you change lanes. But then there's that chance of losing your oil pan over a rail road track. Maybe DirtyT can build me a wood frame so it'll only splinter as I blow down the hi-ways and bi-ways?? **x Brandy
i gopt a 50 and im putting 3 inch blocks and taking out 3 leaf springs that should give you like a 5-6in drop, now what have yall done for the front?
I had 2 inch blocks in the rear of my 50 but it was still nose down due to the removal of 2 3/4 coils. I removed a couple of leaves when I changed the rear end for a 55 chevy. It sat alot better but bags and ch***is work would be the best way to go if you want it ride nice on Australian roads. The worst problem with these Pontiacs is the ch***is hangs down so low under the floor.
Agree with what most have said on this thread(especially Rocky). Put 3" blocks in my '55, and have no problems, unless I have p***engers in the back seat. Just bought an air pump, and air shocks, which will take care of that problem. Brandy, you dropped yours 6"? My gawd, I'd be s****in' the pavement at that!!!
I didn't do it! I bought it already done. Gosh I'm not that retarded. I shoulda known something was weird/wrong when the back seat didn't come in the car. But I was far more interested in the fact the motor was toasted so I didn't think about it til NOW. RIGHT now, she'll never hold any extra weight in the rear of the car. I've got a full tank of gas, no motor or trans and it took 2 people and 1 full size truck to push it up the driveway. I'm gonna change the blocks and see what that gets me, until I can afford airbags all the way round. Most the leafs have been removed so I dunno what my outcome's gonna be. The front coils have been cut so it's riding metal to metal. Gunna need me a good set of bags, compressor, lines, oh my. **x Brandy
And here's my shaft tunnel.................NOW what's a girl to do? I've hi-jacked a thread I've hi-jacked a thread....should change the ***le to lowering the *** on A pontiac. **x Brandy
