How do I restore the machined lip on aluminum wheels?
Discussion in 'The Hokey Ass Message Board' started by exshelby, Jan 21, 2013.
  1. exshelby
    exshelby
    Just picked up a set of American 200s [Daisy-Coke bottle] wheels.
    Somebody used aluminum polish on two wheel lips and two are virgin machined.
    I DON'T want to polish the lips..I want to make 'em look nice as machined aluminum as they were new.
    Anybody know how to do this successfully? Thanks, Jim
  2. noboD
    noboD
  3. oldolds
    oldolds
    Jack up the car, put the wheels on, put it in gear at idle, start sanding!
  4. HOTRODPRIMER
    HOTRODPRIMER
    Correct way,,,
    Cheap way,,but will work. HRP
  5. 1/2done
    1/2done
    from Ohio
    Spin them on a wheel balancer and sand the lip.
  6. 327-365hp
    327-365hp
    from Mass
    Scotchbrite, on a lathe preferably, on the car or on a swivel stool will work too.
  7. Kerry
    Kerry
    Yep, I've chucked some on my lathe and dressed them.
  8. exshelby
    exshelby
    I'm not sure if 'sanding' them is the only way to go. I've done that a couple times before using both methods, a brake lathe and a running car...but the look is not the same as virgin machined. No better way huh......bummed.
  9. saltflats
    saltflats
    from Missouri
    The lathe and if the pattern does not match then you would have to do all four to match or put them on one side.
  10. Yep, it will not hurt a thing to take .0005 to .001 or .002 off of them.
    They actually have a shop here in town that restores aluminum wheels. Lathe is the way to go.
  11. tommy
    tommy
    I just use 80 grit sand paper on a brake drum lathe.
  12. exshelby
    exshelby
    I chucked one up today and first hit it with a scuff pad...too shiny for me, then I hit it with 320...still too fine , lastly 180 which was decent...I didn't try 80....but I will try 100, then 80.
    Before...[​IMG]
    After...[​IMG]
  13. big duece
    big duece
    from kansas
    Looks good, wanna do two of mine?
  14. AREA51SD
    AREA51SD
    For a Machined looked the lathe is the only way. If you are sanding it I would use 120 or 150 grit with WD-40 or PB Blaster. It will leave a nice finish. Here is a Ford grille with a Brush look.
      111.3 KB
      114.4 KB
