Anybody Building Inlinners 4-6-8cyls high or low tech ???
Discussion in 'The Hokey Ass Message Board' started by oldfardyfode, Dec 1, 2011.
  1. Chris F100
    Chris F100
    Here's my 223 - bored .080 over, cammed, Clifford intake and exhaust and Weber 2 barrel...
  2. madflow
    madflow
    from ireland
    my 4 cylinder based on kent xflow block and a OHC conversion from the late 60 s early 70 s
  3. 64falconsix
    64falconsix
    from Daphne Al.
    200 cube seven main ford. .040 cast pistons, A.R.P. bolts, clevite bearings, double roller timing chain, comp 260/.440 cam , large log head with 1.75 SI valves, milled to 52 cc, crane locks and retainers, adjustable rockers ,pocket ported, Offy tri-power with weber 34 ich carbs, clifford dual outlet header, DUI street/ strip distributor.
  4. raprap
    raprap
    from Ohio
    292, bored .040, ported, polished, 3x2 Holley/Webers, 270 dual duration cam, split cast headers, t-5.
