Projects Martin Ford´32 5 Window Build
Discussion in 'The Hokey Ass Message Board' started by tmfcracing, Aug 29, 2011.
  1. tmfcracing
    tmfcracing
    from Sweden
    And all the parts done
  2. Inland empire hot rods
    from so cal
    uuhhhh.....WOW very cool!
  3. tmfcracing
    tmfcracing
    from Sweden
    First thing was to dotweld it together with the tig and grind it.
    Then it was adding bondo and grind it to get radius on the inside edges .
    This panel is the model for future alu casting . All edges need to be angeld to get realese in the sand.
  4. tmfcracing
    tmfcracing
    from Sweden
    Backside of the switch-panel.
  5. tmfcracing
    tmfcracing
    from Sweden
    Frontside
    kiwijeff likes this.
  6. tmfcracing
    tmfcracing
    from Sweden
  7. tmfcracing
    tmfcracing
    from Sweden
    Hangin with tejp. the casted one will be bolted to the dash´s lower edge.
  8. n847
    n847
    Wow...You need to sell that!
  9. redzula
    redzula
    Its funny how many times that phrase has been typed in this thread already. Great work Martin.
    Sent from my DROID device using the TJJ mobile app
  10. James D
    James D
    Amazing build, just all of it.
    I know now, that I know nothing! (I was pretty sure before...)
  11. alchemy
    alchemy
    Rather than worry about draft in the switch holes, just fill them solid on your pattern. Drill the fresh casting when it's done.
  12. tmfcracing
    tmfcracing
    from Sweden
    Thanks. Glad you like it guys =)
    Alchemy, it has crossed my mind. But the holes are 3/4 and ill start to try doing the holes. it has worked before. If it turnes out bad i´ll fill them as you said.
    Ive seen the thread about your Pierce Arrow dash. That is a lot of time spent on that one. Really Great work there =)
  13. tmfcracing
    tmfcracing
    from Sweden
    I might do another version where the lower line follow the stock dash.
    Draw this one today. A little aero inspired ;)
    Do you guys think it would turn out better then the first one ?
  14. Dragrace66
    Dragrace66
    Awesome work.
    Tak su müke (I don't know if i wrote it right) for posting this.
  15. James D
    James D
    Yes. I like it much better at any rate.
  16. rottenleonard
    rottenleonard
    Oh yea, send me the old one and I'll get rid of it for you.
  17. brady1929
    brady1929
    Martin,
    your talent amazes me
  18. Joe Kickass
    Joe Kickass
    Wow, I had to show that lower dash / switch plate to my wife. And then I had to explain why it is so cool.
  19. tmfcracing
    tmfcracing
    from Sweden
    Thank you guys for the coments, I have made the decision not to use the switch panel I did a few days ago. Anyway I am goin to cast a few in case someone else wants it.
    Even the second one that I only have as a drawing (post #553) doesnt feel right.
    My last ideas is a model that has the bottom line as a elipse just as the gauge dash has.
    With a alu frame and a flat surface with a stainless circle-polished sheet .
    Anyway time will tell how it turns out :)
  20. tmfcracing
    tmfcracing
    from Sweden
    I let the switch panel leave my head today and spend this evening to build a gas and brake pedal . My plan was to have some casted pedals but I did it like this instead.
  21. tmfcracing
    tmfcracing
    from Sweden
  22. tmfcracing
    tmfcracing
    from Sweden
    The brake pedal might seems strange, in this little contry there is a law saying that you have to be able braking with your right foot and that the pedal has to be on the right side of the steering column.
    With this one I can use both left and right foot to brake :)
  23. jefscoupe
    jefscoupe
    Sweet. Would make some trick speaker grilles too.
  24. charleyw
    charleyw
    Wow, nice work.
  25. 66tintop
    66tintop
    from Canada
    Martin, you sure make really nice one off trick parts, but you make most of us HACKS :rolleyes: look even worst, I sure am enjoying your thread, thank you for sharing :)
  26. tmfcracing
    tmfcracing
    from Sweden
    Thanks Guys =)
    Folks, not much lately but yesterday my mate Jonny helped me sort out some electrical things. Also been working some with the left rear quarter.
    Bye the way I joined the HAMB Alliance today to support Ryan and this great forum, you guys should do the same =)
  27. DaddyO's..Deuce
    DaddyO's..Deuce
    from Missery
    What ever happened to those wheels you were casting?
  28. tmfcracing
    tmfcracing
    from Sweden
    I need to make time get them finished.......someday , alway a lot of things going on and I need help getting them done who make it even take more time.
  29. OLDTGUY
    OLDTGUY
    Martin, You have amazing talent, Very nice work, Thank you for posting.
    JJ
  30. tmfcracing
    tmfcracing
    from Sweden
    Thank you JJ :)
