I built a hood for my '28.
Discussion in 'The Hokey Ass Message Board' started by metalshapes, Jan 23, 2013.
  1. metalshapes
    metalshapes
    I took the Blower Motor out of my '28.
    The Engine is great, and the blower is too, but the cooling has always been marginal.
    And it has gotten worse, over the years.
    That combined with carb problems ( a pressurised Holley running on the goats piss they sell as Gas these days made things difficult )
    Flooding, hard to start when hot, etc.
    So I pulled the engine before I hurt it with the constant fooding, overheating etc.
    I'll freshen it up, and use it for my Coupe when I build it.
    I put in a pretty mild 350.
    And I tucked in the alt. inside the hoodline ( I'm running an Alt because the engine came with one, and I want to leave my Blower Motor as complete as possible, so I left the Gen on it )
  2. metalshapes
    metalshapes
    So now I didn't have anything sticking out beyond the hood line.
    I startedc out with mocking up the main design in masking tape.
    To see where the louvers were going to be, how many, and how much taper I was going to put in the rows.
  3. patrick english
    patrick english
    from La puente
    Hell yeah!could i have that old rickity blower?..It's my birthday
    Jk,That's guna look sweet
  4. tobyflh
    tobyflh
    from Peru il
    I like this build. Can't wait to see more.
  5. metalshapes
    metalshapes
    After that, I rough cut the panels.
    Put the design on them.
    And tack welded on some 1/2 X1/2" square tubes.
  6. metalshapes
    metalshapes
    Then the fun of louvering began...
  7. metalshapes
    metalshapes
    4 louvered panels...
  8. You are on track!
    Jealous of your location this time of year!
  9. Don's Hot Rods
    Don's Hot Rods
    from florida
    Boy that looks good. Are the steel tubes there to keep the panels from distorting ?
    Don
  10. Stu D Baker
    Stu D Baker
    from Illinois
    Very nice. Subscribed. Stu
  11. metalshapes
    metalshapes
    I got some piano hinges from Master Mc Carr, put them on.
    ( with some repro Model A parts, I had to modify the front one to fit the '32 grille shell)
    Then I rolled the top panels to fit the cowl and grille shell.
  12. metalshapes
    metalshapes
    No, that is to make the louvers end evenly when you cut the slits with the Pullmax.
  13. Now those are some fantastic looking panels,,I like the way the side & hood top panels get large toward the cowl.
    Great attention to detail. HRP
  14. metalshapes
    metalshapes
  15. metalshapes
    metalshapes
    1st testfit with the side panel.
  16. metalshapes
    metalshapes
    Checking the rows for straightness...
  17. flatheadpete
    flatheadpete
    from Burton, MI
  18. metalshapes
    metalshapes
    Side panel cut to size.
    Welded to the hinge.
    And '32 latches and handle put on.
  19. metalshapes
    metalshapes
  20. metalshapes
    metalshapes
    I still need to clean up the welds, and make the gaps more even.
    But other than that, its done.
  21. Hot Rod Apprentice
    Hot Rod Apprentice
    Looks good.
  22. dirtbag13
    dirtbag13
  23. metalshapes
    metalshapes
  24. HELLVIS
    HELLVIS
    coolest roadster ever!...love that top! nice job
  25. AeroCraftsman
    AeroCraftsman
    Looks great. How'd you roll the top section of hood? The louvers would be in the way of using a slip roller. I've got to make my hood soon so I'm going to school on this.
  26. metalshapes
    metalshapes
    I tackwelded a piece of 3" exhaust pipe to the top of a metal sawhorse.
    And then I carefully worked the top pieces over that untill I had the right shape, by hand.
    Its slow and wears you out, but it works...
    I can take a pic of the sawhorse tomorrow.
  27. AeroCraftsman
    AeroCraftsman
    Thanks,
    I kinda figured it was something like that.
    Thanks.....
  28. Very, very nice work. Is that an Abarth Zagato Coupe, double bubble, on the lift?
