64 fairlane 500 air ride
Discussion in 'The Hokey Ass Message Board' started by Redheadedlefty13, Oct 20, 2012.
  1. farna
    farna
    A wider driveshaft tunnel is what I was thinking you'd have to do, only practical way I can see to do it. I wouldn't use that huge pipe though. There's no point in true dual exhaust being over 2" for a cruiser. I know I just made some enemies, but with large diameter pipes the exhaust velocity slows way down at low speed. If the engine is built for high rpm (drag racing, and in some cases road racing) large pipes are required, but a cruiser or street/strip car doesn't need them. Build the engine for good low to mid rpm torque (1000-5000 rpm range) and forget the HP numbers. Big HP numbers are just for bragging rights. Great low to mid torque will get you off the line quick and cruise at high speed much better, and still deliver a decent 1/4 mile time.
    Okay, started getting off track! I'm ***uming you will have a third link (or two for a four link) on your rear axle then. Since the axle hump is behind the seat and cut out anyway I think I'd have mounted the bags directly on the axle. Less weight rating needed that way. Nothing wrong with your way, and I have no real experience with bagging a car, just another way to accomplish the same thing. I don't think it would be any less work though, you'd have to make a high crossmember for the upper bag mount... "my" way might even be a bit MORE work!
  2. Redheadedlefty13
    Redheadedlefty13
    from Avon, Ohio
    the ride quality with bags on the bars is soooo much better and more lift..the bags are 2600 lbs bags a piece...these with a full size truck with a 5th wheel..so lifting the rear of my fairlane is nothing..hell i thinking i lifted the rear with just 45 psi the other day.
    and i set these up so they would clear my back seat...im just going to have to angle the bottom differently to clear the driveshaft tunnel and 4 link... this isnt a big deal since i also do upholstery work
  3. farna
    farna
    I didn't realize the ride was better with the springs positioned that way.
  4. Redheadedlefty13
    Redheadedlefty13
    from Avon, Ohio
    set it up to lay pinch on my 215/70/15s which are .37 taller then the 235/35/20 that will be on it..going to rool the smoothies for daily driving.
    had to pie cut the uppers
  5. Redheadedlefty13
    Redheadedlefty13
    from Avon, Ohio
    going to do the other side tommorow and start the lower control arms one i get the some parts for my tubing bender
  6. rockabilly53
    rockabilly53
    from Appleton
  7. 1951Streamliner
    1951Streamliner
    from Reno, NV
    hahaha you beat me to it.
  8. Redheadedlefty13
    Redheadedlefty13
    from Avon, Ohio
    who ever painted this thing last ran the **** out of it and it looks like ****...not sure if i just want to do a flat black out hot rod flatx 56 corvette red
  9. Novababy
    Novababy
    Do you have any pics of it at ride height?
  10. Redheadedlefty13
    Redheadedlefty13
    from Avon, Ohio
  11. Liam-B
    Liam-B
    from Melbourne
  12. Redheadedlefty13
    Redheadedlefty13
    from Avon, Ohio
    on the ground with the larger 15" wheels and tires up front
  13. Redheadedlefty13
    Redheadedlefty13
    from Avon, Ohio
    going to call tomorrow about some Lincoln Versailles disk brake spindles.. apparently they are good for an inch or so drop
  14. JakeDW
    JakeDW
    from Missouri
    Lookin good.
    Jake
  15. mattrod68
    mattrod68
    tucking 15's like a boss. looks good
  16. Redheadedlefty13
    Redheadedlefty13
    from Avon, Ohio
    thanks man, i have the 20" racelines for it, just not tires yet. I also love the look of the 15" with the small white wall. and for daily driving, you cant beat factory tries that i can find in the yard for $20 a piece.
    i am looking to do a rear steer rack and pinion on the also..as all the factory stuff would hold the front up. I have a power unit from a scion xb that i am going to try out..this that doesnt work, ill probably get one from an old ******
  17. Liam-B
    Liam-B
    from Melbourne
    A lot of guys here are using GM Holden/Daewoo rack and pinion conversions in there old Falcons & Mustangs here in Australia, just need to fab up some simple brackets to mount it to the stock frame holes.
    The trick is to copy this design, should be close on a Galaxie I imagine, will have to find a LHD rack obviously!
    http://www.rrs-online.com/rack-pinion-products.php
    cool
  18. Liam-B
    Liam-B
    from Melbourne
  19. Redheadedlefty13
    Redheadedlefty13
    from Avon, Ohio
    thanks for the link liam, but that rack definately hangs too low..but how they moutned it may work great for my application tho
  20. bonez
    bonez
    from Slow lane
    It would look better on 14" and skinny whites, those wheels are better on a mini.
    Your buddy does awesome work btw, wish i had someone doin my exhaust! Good work still.
  21. Redheadedlefty13
    Redheadedlefty13
    from Avon, Ohio
    to each there own i guess...i guess i just think the more it tucks the better
  22. 60galaxieJJ
    60galaxieJJ
    **** i love this build!
    are you going to box or re-inforce your a arms? i ask because the only thing stopping me from bagging my galaxie is fittings....im soooooo close lol
  23. bonez
    bonez
    from Slow lane
    My 13s with 155s are 24" or so over all diameter.
    Tuckin a fat tire has more street cred than a rubber band on a 22 :eek:
    Just kiddin bro, its all good :cool:
  24. Redheadedlefty13
    Redheadedlefty13
    from Avon, Ohio
    right now my lowers are just a temperary set up until i get my tubing bender stand together..i have to make new ones bc they hit the frame pretty quickly and i am getting rid of the trialing arms and triangulating the lowers
    the uppers i am going to box with some 3/16th
    my 15" are almost 27" tall
  25. BurntOutOldMechanic
    BurntOutOldMechanic
    from NOVA 22153
    Dude, I love the "Go to Hell" look of yer' ride and I've suddenly gone queer for these steelies:
    Keep doin' what yer' doin'...
  26. cartoon14
    cartoon14
    looks bad ***s....love'm lowwww. 20's are a nice touch when there tucked in the wheel house.
  27. What up John. Your build is so bad*** man. Guess I can keep up with it here and on the gram, lol..... Funny, I got those same Racelines on my mini. Been scheming on throwing one on my Apache for ****s and giggles, ha!
  28. Redheadedlefty13
    Redheadedlefty13
    from Avon, Ohio
    ya..figured I could switch it up..the nitro steelies are cool but to get the other 3 shipped to me would cost $350 And I bought the 4 racelines for $500..also figured if I ever build my 88 ranger I can put those on it also
  29. Redheadedlefty13
    Redheadedlefty13
    from Avon, Ohio
    haha..thats what i am going for..oh and that gap between the rocker and the ground is gone now
  30. Redheadedlefty13
    Redheadedlefty13
    from Avon, Ohio
