stock rear end
Discussion in 'The Hokey Ass Message Board' started by JOHN QUESADA, Jan 23, 2013.
  1. JOHN QUESADA
    JOHN QUESADA
    I could use some advise.I bought a 54 plymouth plaza .it came with a fresh rebuilt stock 307 along with a 700r trany.but it has the stock original rear end.the drive shaft has the newer u joint in front and the rear has the orignal ball pin u joint but new.Im having some work done to the car and havent driven it yet. will i have problems with this set up and will it be safe.your feed back is much appreciated.thank you john
  2. Hnstray
    Hnstray
    from Quincy, IL
    Some factory Mopar driveshafts where equipped with the two different type u-joints as I recall. The so-called "pot' type (there is an official name) is spring loaded inside to center it. I doubt that will give you problems.
    However, of greater concern might be the fact you have no operating parking (emergency) brake with the transmission you have. I know you have a "Park" position, but an operable parking brake would be beneficial. An Jeep Cherokee 8 1/4" axle from a 6/automatic is 3.55 and would work well for your application. So would a Ford 8" or Explorer 8.8. The Cherokee would be the simplest to swap, I think, given you current setup.
    Ray
  3. Ray,
    He could actually use a wheel chock for a parking brake.
    I'll bet between us you and I don't have enough fingers and toes to keep score on that one. :D:D:D
    I used to have this Ford pickup with a 3 speed. The park brake was non existant and it didn't have enough compression to hold itself on a hill so I carried this perfect shaped rock in the bed. Sometimes getting in from removing the rock was pretty humorous.
    Anyway long story short, someone asked me in a parking lot one time if that was my E brake and I said. "No, its a door key, if I lock myself out I just fling it real hard at one of the windows. :D"
  4. Hnstray
    Hnstray
    from Quincy, IL
    Benno,
    There is no one on the HAMB whose posts I enjoy more than yours! Keep 'em coming! That "door key" retort is hilarious :)
    Ray
  5. aaggie
    aaggie
    In Texas you have to have a working emergency brake to p*** the state inspection and get the windshield sticker. The guy doing the inspection sets the brake and hits the gas, if the car moves it fails.
  6. JOHN QUESADA
    JOHN QUESADA
    6-71
    I have a friend who had a 32 Ford 2 door with a 4-71 blown 340 and a torqueflite,with that enclosed"pot" type u-joint. He beat it pretty hard,even drag raced it,and he never had a problem with the u-joints.;)
  8. JOHN QUESADA
    JOHN QUESADA
  9. I'm thinking the rear end you have is probably geared too low for comfortable cruising. The car was born with a flathead 6 and 3 on the tree, so it was geared low, even lower if it came with overdrive. The rear end will probably handle the power of a fairly stock 307,but there are probably few gear ratio options. Measure the width of your rear compared to a Ford 8" from a Maverick or Granada that came with a 302 and automatic. Better cruising ratio and it solves the parking brake problem.
  10. JOHN QUESADA
    JOHN QUESADA
  11. Frankie47
    Frankie47
    from omaha ne.
    You could get a 3.73 from ma mopar when new.......:)
