Magneto on SBC for street use
Discussion in 'The Hokey Ass Message Board' started by txcr13, Jan 24, 2013.
  1. txcr13
    txcr13
    What issues could I expect if I were to run a Vertex magneto on a street rod? Car would have a warmed up 400ci SBC and driven occasionally on the street, but not a daily, high mileage driver.
    Thaks foryour help.
  2. Had one on my 348 with a small battery and had no problems.
  3. Ran one in a small block Ford street car for about a year with no problems.
    Lots of static in radio.
    Used a single position light switch for ON-OFF
    Push ****on for starter.
    SPEEDY
  4. txcr13
    txcr13
    Thanks, gents. I wont have a radio so no issue there. Many years ago I also ran a mag with off-on switch and push ****on for starter, but that was a strip only car.
  5. Jmountainjr
    Jmountainjr
    For street use you'll want to have working advance and not run one locked out. The kit can be installed in any Vertex should yours have a fixed plate. I believe you have two choices - 7 deg & 12 deg. That distributor degrees, so double for crank degrees. So with a 12 deg advance in the mag and 10 degrees initial you'll get your standard 34 deg all in. Many places can alter the degree curve for your application.
  6. olcurmdgeon
    olcurmdgeon
    I ran both a Vertex, in my '48 Chev, and a Pounden magneto in my '32 phaeton, both on th street with no problem. You'll have to gap your plugs tighter, .018 if I remember but it was a long time ago. And yes, just a toggle, rated for the application, as a kill switch. Used to be quite a few places that would check out/rebuild magnetos but that was when the circle track guys used them. They have all gone electronic and for a while the circle track swap meets out here had lots of mags for decent prices.
  7. txcr13
    txcr13
    More good info!!! Thanks, Jim & Olcurmdgeon!!
  8. i ran a vertex for years on a 354 blown hemi. it started and ran great. the plug gap was .020. use the correct plug wires for a mag. solid core i believe.
  9. TV
    TV
    I run a vertex on my 350 sb in my 32 pickup. Had it on there for 5 years now with no troubles. She is wormed up to about 500hp with a 4 speed and a 9 inch love it lotsa fun to drive.--TV
    glenn larsen and Elcohaulic like this.
  10. flamedcoupe
    flamedcoupe
    Ran one for about 65000 miles in my 3 window. Never had a problem but always had a complete ignition system in the trunk. Hard to find mag parts on the road coming home on Sunday.
  11. HomemadeHardtop57
    HomemadeHardtop57
    No problems. Put it in and run that *******
  12. 60srailjob
    60srailjob
    from nowhere
    Hey thanks for the thread......that will help me too......does it differ on CID?
  13. 60srailjob
    60srailjob
    from nowhere
  14. txcr13
    txcr13
    ??? Think I missed something...not unusual for me though.
  15. DirtyDave
    DirtyDave
    I want one for my g***er 39 Hudson build!
  16. dreracecar
    dreracecar
    from so-cal
    Taylor/Vertex has a Relay kit that one can run a Mag and standard Ign/starter key switch
  17. Old Tin and New Tin
    Old Tin and New Tin
    Ran a Vertex magneto on my 5 window with SBC for a year after two Taylor-Vertex look-a-like distributors ****ped out. I wired mine through a relay so my ignition switch controlled the use of ground
    when starting and turning off the engine. Magneto worked great and fired almost instantly. Only problem I had was with my SW electric speedometer as the magneto noise drives it crazy. Tried filters and grounded and shielded wiring but it didn't help. After a year and a half Taylor-Vertex finally got my look-a-likes retrofitted
    and I went back to them. A year on those units and they are working great and do not affect the speedometer.
  18. DirtyDave
    DirtyDave
