Main Bearing Studs
Discussion in 'The Hokey Ass Message Board' started by One Finger John, Jan 25, 2013.
  1. One Finger John
    One Finger John
    I have an opportunity to buy a full set of main bearing studs for a SBC Chev (2 bolt main). I emphasize that the set is used. The set has been thru at least 30 torque and release cycles (used for engine mock up, etc.).
    Does any one know what the life of a quality stud (ARP, Donovan, etc.) would be?
    How many stretch cycles can they go thru before they are deemed overworked or over stretched and thus, unusable?
    Since I suppose the same question would apply to rod bolts (not nuts) also, would they be in the same boat?
    TIA, John
  2. 60srailjob
    60srailjob
    from nowhere
    I dont think their like torque to yield, but why not just buy a new set....just a question
  3. TR Waters
    TR Waters
    from Vermont
    Under $60.00 for a new set of ARP. Dont waste your time with used.
  4. 60srailjob
    60srailjob
    from nowhere
    Thanks for the price TR, I didn't know how much they where.....I agree....NEW
  5. 60srailjob
    60srailjob
    from nowhere
    I guess if they where dirt cheap, (free) then I'd get them for maybe a mock up motor..or something
  6. One Finger John
    One Finger John
    Well O.K. I'll purchase a new set of studs. Ya talked me into it.
    Back to my original question... How many torque cycles can a quality stud go thru before it should be replaced? Can they be handed down from one generation to the next generation or are these studs a use once and replace type of deal?
    Can they go on for years doing their job, or should they be replaced with the creation of a new motor. Kinda like the situation I face now, they are used, what is their life span?
    John
  7. 60srailjob
    60srailjob
    from nowhere
    check ARP's web site and check with one of their people.......
  8. black 62
    black 62
    from arkansas
    putting them in your parts truck they will last a lifetime ---good for at least two in high rpm applications--- at least that is what i told myself when i reused mine
  9. 34toddster
    34toddster
    from Missouri
    I just don't think they will ever give up, I'd look at the threads on the top side that hold the caps on for distortion in the thread area. I've seen them used in race motors forever. Rod bolts a far different story!
  10. gas pumper
    gas pumper
    Steel can be cycled as long as you don't exceed the elastic limit. That means they will stretch a little and come back. If they were streched a lot and exceed the limit, they would be longer. And usually the threaded portion is what moves. Then the nut won't go past the stretch.
    I'd be more concerned that the PO ran nuts on and off with an air gun and the threads are nice and loose. And prone to stripping at some point.
    Main Studs are a lot less stressed than rod bolts.
    Frank
  11. dreracecar
    dreracecar
    from so-cal
    To answer the question one would have to purchase a set of GO-NOGO gauges to check the pull on the threads
  12. bobss396
    bobss396
    Normal street use and some beating on it now and then, I'd take them for free. I would splurge on new nuts though.
    Bob
  13. CNC-Dude
    CNC-Dude
    They should have the stretch data on their website, as long as they still meet their recommended stretch value they should be fine regardless how many times they have been torqued.
  14. One Finger John
    One Finger John
    BTT for the afternoon/evening shift. Unless your at the GNRS, then enjoy the show.
