Projects 59 f100 build
Discussion in 'The Hokey Ass Message Board' started by Freeberg, Dec 14, 2012.
  1. Freeberg
    Freeberg
    I'm new here on this site. I was told to do a build thread so I hope this I right. I just got the truck and I stripped it to the frame and now I'm in the middle of c notching the frame and flipping rear axel. Here's the truck and my progress.
  2. Freeberg
    Freeberg
    Another
  3. Freeberg
    Freeberg
    C notch
  4. Freeberg
    Freeberg
    More
  5. Blake84
    Blake84
  6. Freeberg
    Freeberg
    Finally got the c notch in the rear done. Now the front axel is off to sid's!
  7. Freeberg
    Freeberg
  8. Freeberg
    Freeberg
    Can someone help me on where to get mono leafs for my truck??
  9. Hotrod1959
    Hotrod1959
    Are you sure you want mono leafs? I do not have any experience with them but several guys that I know have installed them on their F100s and have not been happy with the ride. A friend of mine lowered my F100 and used the stock springs with some mods. On the fronts he removed a middle leaf and had the eyes reversed. He also moved the front upper shock mount up 3 inches which allows you to use stock shocks. On the rears (depending on condition of the springs) he flipped the rear leaf spring shackle which brings the spring eye up. If you want to see some pictures here is the build link.....
    http://www.jalopyjournal.com/forum/group.php?do=discuss&group=&discussionid=16547
  10. Blake84
    Blake84
    Ya I would probably go with reverse eye
  11. 100% Matt
    100% Matt
    Mono leafs ride terrible..... ask me how I know. Reverse the eyes and removing one leaf up front with a Sids 3" axle will give you a great ride and a nice drop. Posies is also set to release a twin-spring duel leaf set up for 57-60 trucks similiar to the one they do for 48-51 and 52-56 F-Series
  12. Blake84
    Blake84
    I had a sids axle with tie rod extensions before I bagged mine. Curious you look like you have some welding and fab skills from seeing your notch why not put jag or camero front clip in and get power steering disc brakes lower truck and independent suspension for better handling. A clip and a junk yard is prob around 500 bucks pretty close to a drop a le and tie rod extensions. Just a thought it makes a HUGE difference
    Plent of threads on here with jag swaps
  13. Freeberg
    Freeberg
    Thanks for the help,ok scratch the mono spings! I'm new to all this, it is my first truck build. But I've already sent my axel to SIDS for a 3 inch drop so it's to late for a different front end but I'm tryin to get it as low as I can with a decent ride. Thanks again!!
  14. Freeberg
    Freeberg
    Do they make dropped spindles for my f100, if so where can I get them?? Thanks
  15. 100% Matt
    100% Matt
    The yellow 59 has a 3" Sids drop axle and one leaf removed with reversed eyes. The gold and white truck has a M2 kit
  16. Freeberg
    Freeberg
    I've seen a picture of that gold truck and I LOVE that color, that's what I wanna paint mine but ok thanks.
  17. Blake84
    Blake84
    Make sure you get tie rod extensions with the 3 inch drop axle or you will be pissed and have to figure out how to fab some
  18. Freeberg
    Freeberg
    Ok thanks will do!!
  19. willowbilly3
    willowbilly3
    from Sturgis
    My next project is a 60, gonna be a budget junkyard dog build. I have been doing quite a bit of pondering and measuring to put a Ford Aerostar front under it. Cheap or free, only an inch wider than the F100, disc brakes, rack and pinion steering. Then flip the front spring mount to lower the rear and use a 3.73 L Exploder rear.
  20. Freeberg
    Freeberg
  21. ChefMike
    ChefMike
    great staart and welcome
  22. Freeberg
    Freeberg
    Still waiting on my SIDS axel ,so ready to get back to work on my truck!!
  23. Freeberg
    Freeberg
    Got my axel today and put it back together... I have a question can use my stock shocks with my 3" drop axel?
  24. Freeberg
    Freeberg
    Also where can I get new Crome trim to go around windshield?
  25. ArizonaBill
    ArizonaBill
    from Arizona
    yes, if you did not take any leafs out you should be fine....
    Stainless Steel Windshield trim is not reproduced that i know of. you will need to find it used.
  26. Freeberg
    Freeberg
    Ok thank you for the info... Also what shocks do I put in the rear I flipped axel and took 3 leafs out?
  27. Hotrod1959
    Hotrod1959
    You can use the stock shocks but you will have to remove the mount and relocate it up 3 inches.
  28. Hotrod1959
    Hotrod1959
    this was remove one leaf and reverse the eyes on a 59....
  29. Freeberg
    Freeberg
    Thanks yeah I was looking at your build forum while puttin mine back together, looks great.
  30. SinCityRatFink
    SinCityRatFink
    from Layton, UT
    Any updates on the build?? Did you reverse the eyes on the front? Have a 58 and would like to see your stance..
