metal flake
Discussion in 'The Hokey Ass Message Board' started by convict, Jan 26, 2013.
  1. convict
    convict
    from laredo,tx
    How easy or hard is it to paint metal flakes, I wanna paint ch***is n firewall, any suggestions???
  2. saltflats
    saltflats
    from Missouri
    The bigger the better ... thats what she said
  3. rocketsled59
    rocketsled59
    After typical prep work is complete,First step is to spray with a like colored base coat This helps any voids between the flake from showing what color is underneath. Spray flake till covered nothing looks worse than not enough flake think b*** boat drumset dunebuggy The larger the flake size the rougher the finish will be. It requires alot of clear and color sanding and a final clear to achieve a slick final finish. In short , it's a ****load of work...no steps can be skipped...it has to be done properly. But it looks bad***. And that's why it's worth th EFFORT. Flake it!
  4. Rusty Kustoms
    Rusty Kustoms
    Also keep in mind the spray gun tip size requirements for the flake you plan to spray. Your basic spray gun will not work as most flake is 1.5 or bigger, look for a gun with at least a 2.5 tip.
  5. jimbousman
    jimbousman
    Do a search on this site and you will find a wealth of knowledge on the subject
  6. rocketsled59
    rocketsled59
    I've sprayed pretty big stuff with a 1.8. I just use my primer gun.
