Econoline straight axle disc brake conversion?
Discussion in 'The Hokey Ass Message Board' started by 1971BB427, Jan 27, 2013.
  1. 1971BB427
    1971BB427
    from Oregon
    Does anyone know of a kit to adapt disc brakes to the frontend of an Econoline straight axle? I'm looking to swap the Econoline axle into a g***er project, and would like to have disc brakes over the drum setup.
  2. AREA51SD
    AREA51SD
    Give D & D a call they make a kit for Ford vans (541)740-9468.
  3. 1971BB427
    1971BB427
    from Oregon
    Thanks! Looks like they're in my neighborhood too from the area code!
  4. stewartwhite
    stewartwhite
  5. Unkl Ian
    Unkl Ian
    I think there are a couple decent options, hit the Econoline forums.
  6. 1971BB427
    1971BB427
    from Oregon
    Sounds like good options here. Thanks again guys! The axle is going under a '63 Falcon Futura project.
  7. FlynBrian
    FlynBrian
  8. willowbilly3
    willowbilly3
    from Sturgis
    I built my own for cheap. I used those cheap weld on brackets the dirt track suppliers sell for the rear and modified them to bolt on (they now look just like the ones in the kit in the link above). Summit or Speedway should have them. Used GM metric calipers. If you have the econiline hubs, just knock out the studs and remove the drums. Crown vic rotors will fit right on those hubs. I used Aerostar rotors so I could run 14" wheels.
    With the brackets, new calipers, grade 8 bolts, hose kit from Speedway, I have around $100 into mine. I got used rotors for free.
    indyjps likes this.
  9. 1971BB427
    1971BB427
    from Oregon
    Really great information! Thanks! I'm all about doing it cheaper!
  10. dan c
    dan c
    i recall a piece in hot rod magazine--probably in the 70s--on how to do it. may be in hrm archives.
  11. bgaro
    bgaro
    what are u guys using for a master cylinder? thats good info to fit the 14" wheels, i want this set up in my 61 econoline, but i know those masters are tiny.
  12. saltflats
    saltflats
    from Missouri
    What kind of wheels are you going to run? Do you think a vented rotor will look heavy on the front I am planing disc for the front of my 61 P/U but I am no were close for that part yet.
  13. 1971BB427
    1971BB427
    from Oregon
    Way too early to think about wheels yet, but hopefully something traditional like old slots or some early spoke.
  14. saltflats
    saltflats
    from Missouri
    I guess it depends on if its for the street or track.
  15. GrouchySS
    GrouchySS
    I have an econoline axle in my 63 nova and i got my caliper brakets from Dennis farris I forget the name of his company but I have all the info at home VERY GOOD product and great to work with pm me and Ican get you more info
  16. Hellfish
    Hellfish
    I used the D&D kit on my '65 Econo. Works great, easy to install, and Dennis was always quick witha resopnse when I had questions. I used a '77 Maverick dual MC. It works pretty good. I think it's a 15/16" bore, but I've been told that a 1" bore would be even better. No problems so far. I bought a dual MC bracket from Fred Carillo (who is on the HAMB somewhere), but this guy also sells a complete set up
    http://www.themodernform.com/econoline/econoline_master.html
    Lots of great info here on the HAMB on this install
    http://www.jalopyjournal.com/forum/showthread.php?t=159016
    If you keep up with the Econoline/old van forums you'll meet a guy named Vic who makes a really nice (but more $$ than D&D) disk conversion kit. I think his uses AMC parts.
  17. Hellfish
    Hellfish
    That's D&D ... http://www.dddiscbrakes.com/kits.html
    Dennis & his son also make other parts, like rear roll pans.
  18. willowbilly3
    willowbilly3
    from Sturgis
  19. 1971BB427
    1971BB427
    from Oregon
    Thanks again for all the great replies, and so many options! Just bought the Falcon this week, but I've had the Econoline axle since last year when I bought it with this type of project in mind!
    Wont be starting the g***er build for awhile, as we're remodeling the house, but hopefully by spring it will begin!
  20. 55 dude
    55 dude
    i talked to dennis when i had my 65 econoline pickup and i do believe they used jeep grand cherokee rotors. those weld on brackets sound like great option to me and wasn't their a place that supplied circle track cars for disc brackets and they were cheap, like $10 a side!
  21. 1971BB427
    1971BB427
    from Oregon
    Dug up all the parts to make up the kit you mentioned. New rotors from Autozone were $56 a pair, Camaro calipers $32 a pair. Speedway bracket under $20 a pair. Just over $100 for the changeover. Subtract whatever I can get out of the two brand new brake drums, wheel cylinders, brake shoes and spring kits, plus used backing plates. I may be into it pretty darn cheap if there's a market for the new/used Econoline parts!
  22. wheels777
    wheels777
    from York, PA
    Does anyone sell the adaptor plates only?
    What are the wheel studs used in the stock hub to locate the disc?
  23. 1971BB427
    1971BB427
    from Oregon
    See post #2.
  24. Puddin Head
    Puddin Head
    from Mason, Oh
    Go to carnut.com, then go to the tech page. Has a 61-67 Econoline disc install. If you contact him he will send you a template and all the bolt on info. I did this a few years back and worked great.
  25. wheels777
    wheels777
    from York, PA
    I found everything on the installation process. But nothing on the parts and a way to contact. Does anyone have contact info?
  26. 1971BB427
    1971BB427
    from Oregon
    This is the method I'm using. Purchased the Speedway weld on brackets and I cut and drilled them to fit the backing plate pattern. The rest the parts I got at Autozone cheap. The GM calipers were $15ea., the rotors were also $15ea., and hoses from my local supplier were $12ea. for braided SS hoses.
  27. wheels777
    wheels777
    from York, PA
    Which rotors?
  28. 1971BB427
    1971BB427
    from Oregon
    Crown Vic if you want to run larger wheels, and Aerostar if you want to run something closer to stock, like 14" wheels.
  29. 1971BB427
    1971BB427
    from Oregon
    Have another question for the E100 experts. I still haven't installed the conversion on my E100 axle, although I have all the parts, but I started helping a friend do his axle today. When we pulled the wheels I discovered his hubs have pressed drums on the hubs, but mine are a slip fit, separate from the hubs. After a lot of work, I finally got the hubs separated from the drums, only to discover the hubs wouldn't fit inside the Aerostar rotors! Had to chuck the hubs in my lathe and turn them down about 1/4" overall to allow them to fit.
    Did Ford change from press on to separate drum/hub, and did the hub size change externally when they did so?
  30. 1971BB427
    1971BB427
    from Oregon
