What to use to drill an axle???
Discussion in 'The Hokey Ass Message Board' started by choptvan, Jan 15, 2013.
  1. lawman
    lawman
    I think this was covered last month but it is still good info !!!
  2. choptvan
    choptvan
    tell you what, if it was, I typed the wrong key words into the search function.
    Thank you all for contributing.
  3. Keep
    Keep
    The center pulley is the slow speed attachment allows you to drop the speed to a crawl. Cost me about $20 to make and $18 of it was the pulley and belts.
    I actually posted how to make this over at the garage journal. Let me see if I can find the post
  4. Keep
    Keep
  5. KeithDyer
    KeithDyer
    /\ /\ /\ /\ What he said . . . .
    My Heat Exchanger shops use these to drill heavy 70 ksi steel vessel shells.
    And the Cool Mist (air / water / soluble oil mixture) is the way to keep it cool and lubed up to fight a long time!!!
    Take care, K
  6. choptvan
    choptvan
  7. lango
    lango
    from Georgia
    Man, you can learn a lot here...
    Sent from my DROID device using the TJJ mobile app
  8. choptvan
    choptvan
    and one more bump just to see what else we come up with
  9. BIG-JIM
    BIG-JIM
    from CT
    My drill press goes down to 200 RPM's. Is that slow enough to use a hole saw on steel & aluminum?
  10. Deuces
    Deuces
    Indexable spade drills work great also... These drills use a TiN coated carbide tip that attach with 2 small screws... Also, make sure the work piece is mounted solid in the vice...
    And wear safety gl***es!!!!!!...;)
  11. BillyM
    BillyM
    Roto-broach makes drilling any through hole REALLY easy. I have access to the ones' we have at work, but I'd bet you could rent one through any industrial tool rental.
  12. ago
    ago
    from pgh. pa.
    Roto-broach really works very well.
    Ago
  13. Blue One
    Blue One
    from Alberta
    I know them by the name that says what they really are which is annular cutters.
    My mag based drill and 1 1/8" annular cutter is what I used for my forged axle.
    A squirt bottle filled with water soluable oil as coolant is all you need to cool and prolong the cutters life.
  14. choptvan
    choptvan
    We got a long way through today drilling our axle. We have 4 holes left. 21 total. So I will post pix soon as I get it all done on monday. Thanks for all of the tips. Drill press worked wonders. Never actually had the chance to use one. Slowed it down as much as I could and used about 1.5 cans of PB blast.
  15. shtterbug8
    shtterbug8
    what is the standard safe spacing for the holes most people go with? ive seen several varieties on this post. 7/8 hole to 1 1/4 hole. spacing looks to be from 1inch apart to almost 1/4 apart.
  16. bronco gasser
    bronco gasser
    from GB WI
    I used drill press with drill bit clamped down to bed worked out fine no problems also did the wish bones the same way used them for my traction bars looked great for abunch of used parts.
  17. choptvan
    choptvan
    here is how ours turned out. 22 holes in total.
  18. hoghousehotrod
    hoghousehotrod
  19. mattrod68
    mattrod68
    i was under the impression that blocks were verbotten on front axles (driven or otherwise)?
    just curious
    matt
  20. choptvan
    choptvan
    Verbotten? Meaning???
    I have seen quite a few setups that way. Was never told not to. Seen more than a few setup sthis way. Hell. I have even seen extended shackles. But, we don't want to get stupid high with the front of it.
  21. mattrod68
    mattrod68
    http://www.jalopyjournal.com/forum/showthread.php?t=439377
    verboten meaning forbidden. the cornering forces on the blocks in the front are immense. anyway not trying to troll just what I've rad and been told, thought i would bring it up so you had all the info.
    keep up the good work on the f100
    matt
  22. choptvan
    choptvan
    well ****. Ok. Got to look into that. Thanks. Never heard of any of these problems till now. Go to check this out more.
  23. CGkidd
    CGkidd
    Looks cool. I would go with new leaf springs for a 4 wheel drive F250. They will probably raise the truck up as much as the stock leaf and blocks.
  24. 19Fordy
    19Fordy
    Oil is not needed when drilling cast iron because the high carbon content acts as a lubricant.
  25. gimpyshotrods
    gimpyshotrods
    Yeah, except most axles are forged steel, with a handful of aftermarket cast steel ones.
