Split manifold
Discussion in 'The Hokey Ass Message Board' started by corvair63, Jan 23, 2013.
  1. corvair63
    corvair63
    from denver
    Has any one made a split manifold for a ford 144 or 170 if so please post some pictures it would be much appreciated cause I can't find any that are pre made
  2. bonez
    bonez
    from Slow lane
    144 is a six? or a 4? I dont think theres any premade ones, but if you go to www.losboulevardosmessageboard.com and do a search a tech should pop up. I can tell you it was user fu-manchu that did it. Hope it can be of some help.
  3. blyndgesser
    blyndgesser
    from Georgia
    144 was the original Falcon six. You might check at www dot fordsix dot com to see if anyone there has ideas.
  4. garvinzoom
    garvinzoom
    Clifford makes a header, I have one in my 170.
  5. corvair63
    corvair63
    from denver
    Garvinzoom how is that header? Is it worth the price?
  6. garvinzoom
    garvinzoom
    I like it, seems well built. Not sure if it added any performance advantage but that wasn't what I was after.
  7. corvair63
    corvair63
    from denver
    Did it just bolt right in or did you have to do some modifications to get it to fit in?
  8. garvinzoom
    garvinzoom
    Had to trim the positive terminal on the starter down to give one of the pipes some breathing room, it cleared but was to close for me. The stud seemed excessively long anyway so not really a header issue.
  9. garvinzoom
    garvinzoom
    Think my local exhaust shop only charged around two hundred for duals out to the rear bumper.
  10. bonez
    bonez
    from Slow lane
    200 is a pretty good deal. The closest shop in my area that does this kinda work is an hour drive away and wanted 400 euros. Neither to say i said screw it and i'll do it my self.
    I have 4-2-1 heder too, im just gonna remove the last bit and use it as a proper splitty.
  11. Dynaflash_8
    Dynaflash_8
    from Auburn WA
