HAMB wife broke down near Columbia, MO
Discussion in 'The Hokey Ass Message Board' started by raven, Jan 28, 2013.
  1. HOTRODPRIMER
    HOTRODPRIMER
    I can't do anything but bump the thread,,good luck,,sounds like a lot of guys are trying to help! HRP
  2. hotrodharry2
    hotrodharry2
    from Michigan
  3. kyvetteman
    kyvetteman
    The H.A.M.B. is awesome!
    It's great that so many are trying to help these folks...makes me proud to be ***ociated with ya'll.
    Bump
  4. '40PlyCoupe
    '40PlyCoupe
    Howdy,
    If she needs an honest repair shop take it Simpson Import Center and talk to Brad Cunningham - the owner. I grew up in Columbia, Mo and have known Brad for years.
    Good luck,
    Adam Wellman
  5. black 62
    black 62
    from arkansas
    lots of good people in Mo.---good luck
  6. budssuperpro
    budssuperpro
    I just talk to James Schrader on the phone and he said he would help anyway he can. He is also a hamb er .
  7. raven
    raven
    Ok, first is they make it safely to our daughter's place. (Ran nearly an hour on a different battery, that's an answer to prayer)
    I called James Schrader and left a message. I also gave my wife the number.
    Atch is taking the truck to O'Reilly's to have them test the battery and alternator.
    They might be able to fix it tonight. We'll see.
    Thank you eveyone!
    r
  8. raven
    raven
    "lots of good people in MO"
    That's an understatement!
    That's why I live here!
    r
  9. budssuperpro
    budssuperpro
    No problem glad I could help. anytime..
    and beleave me James is a good guy and will help you to get going again.
  10. raven
    raven
    I just spoke with him.
    Atch told me that the battery had a dead cell. That is being replaced. My thought is the alternator is suspect too since it should run without a battery...
    r
  11. Robin,put in a Deep cycle marine battery,or use jumpers from it to the main battery[walmart]it will run a car about 5-7 hrs with no alternator charge at all....just to get home
  12. freakishly the low tonite here is only gettin down to about 60degrees....jus a few days back it was only 9 degrees daytime highs....
  13. raven
    raven
    Very glad about the weather.
    Better than having to withstand 10 degrees while changing things.
    r
  14. fastcar1953
    fastcar1953
    glad everything turned out o.k.. let's hope just a battery.
    yeah the weather is crazy. wait till wednesday ,, snow and freezing rain. she got lucky with the weather.
  15. HOTRODPRIMER
    HOTRODPRIMER
    I know it's gotta be hard sitting around with your spouse broke down away from home,,great to have some hambers around to offer help. HRP
  16. raven
    raven
    Don't you know it!
    I appreciate all the help!
    r
  17. budssuperpro
    budssuperpro
    Yup your right the truck should run with a bad battery on just the alternator as long as the rpm are kep up and leave off the AC, radio, so you might want to check the output of it.
    Good Luck Bud.
  18. Bump
    Later,
  19. elgringo71
    elgringo71
  20. saltflats
    saltflats
    from Missouri
    Hay if thay dont get it fixed or need an alt have them call me early I can pick up a used one if you want I drop my boy off at the salvage yard on my way in so I am at the shop at 8. hope thay are safe. James
  21. The power of the H.A.M.B. is relentless...and the people of the H.A.M.B. ARE the H.A.M.B.!!!! Good folks on here!!!!
  22. raven
    raven
    She will call you in the morning. I don't trust that the alternator is doing it's job. After the new battery was put in, there still was an idiot light in the shape of a battery on the dashboard, she told me.
    Thanks for all the help folks. My wife and I appreciate it.
    r
  23. saltflats
    saltflats
    from Missouri
    Cool I can pick up a used one if money is tight or we can get one from slow reily.
  24. DAMN Dude, I just changed jobs and that came with a change of hours, I just saw this. I would have been there in a heart beat. Dean
  25. lothiandon1940
    lothiandon1940
    The HAMB Community.........No better place to be. Hope it all gets sorted out and your wife gets home safely.
  26. goatboy
    goatboy
    from kansas
    very cool guys, never thought of doin this ! theres a bunch of stand up dudes on here, great to be a part of it, hope i dont have to use it but nice to know the help is there.
    goatboy
  27. oldpl8s
    oldpl8s
  28. So no one called me? I am amazed a couple of hours ago 5:30 I still could have gone after her.
  29. Mnhotrodbuilder
    Mnhotrodbuilder
    from Afton, MN
    He didn't want you putting the moves on his old lady P&B!:rolleyes:
  30. I always do. Problem is that putting the moves on your sis just isn't accepted in this state. :eek:
    OK now someone tell me that atch got her and she is OK.
