Question for sbc gurus
Discussion in 'The Hokey Ass Message Board' started by Two50s, Jan 29, 2013.
  1. Two50s
    Two50s
    I Have a SBC in my Coupe with a sequence of numbers stamped on the pad on the front p***enger side of block, V0503T. Under that row of numbers is another set of numbers C3J114351.
    I have had no luck decoding these numbers. Any help will be apperciated.
  2. Speed Gems
    Speed Gems
    So far all i got is your block came from Flint MI on May 3rd.
  3. Two50s
    Two50s
    Apperciate any help. I have searched and searched and nothing.
  4. Rattle Trap
    Rattle Trap
    Well I guess you found out it's a 1973 350.
  5. 33sporttruck
    33sporttruck
    Last six digits in the second number is also the last six digits of the vin # of the car that the motor came in....................................... Jeff
  6. 54nomore
    54nomore
    from illinois
    And the "C" indicates truck. Chevy car would have started with "1".
    The "J" is the ***embly plant for the vehicle, but I don't know what city that is.
  7. plymouth1952
    plymouth1952
    check the number on the bell housing flange
  8. 54nomore
    54nomore
    from illinois
    I should have mentioned that the "3" (second digit) does indicate 1973 model year, though Rattle Trap suggested you already know that.
    It can only be a 307/115hp or a 350/155hp. Aren't there any more letters after the "T"? The engine code should be three letters.
    Yes, also what plymouth 1952 said.
  9. Two50s
    Two50s
    Thanks a lot guys, that helps.
    Plymouth 52, there is a casting number on the Bell Housing, but the numbers are so messed up I can't tell what the last three are. I am pulling the front clip off and engine out soon to put a Jag Ifs under it, maybe I can determine what those casting numbers are then.
    54nomore, there are no letters after the T. I have looked till I'm almost blind trying to find more letters. Hard on my old eyes.
