Can a sprint car type torsion bar suspension work on a street driven hot rod??
Discussion in 'The Hokey Ass Message Board' started by Devin, Oct 4, 2012.
  1. Devin
    Devin
    from Napa, CA
    Like sThe subject says. I like the clean look and sense of purpose of sprint car suspensions. Perhaps with less machined aluminum and more fabrication.
  2. Devin
    Devin
    from Napa, CA
    Rear suspension to be specific.
  3. gimpyshotrods
    gimpyshotrods
  4. vtwhead
    vtwhead
    My buddy scratch built a 27 T roadster with a flat head and a quick change and installed torsion bars from a sprint car. Came out real neat and although he does not drive it much he says he was quite satisfied with the ride
  5. gnichols
    gnichols
    from Tampa, FL
  6. XWYNNSGUY
    XWYNNSGUY
    You need to check out Joey Saldana's hotrod, torsion front and rear I think. built and set up by Lee Osborne. Who was one heck off a shoe himself.
  7. Devin
    Devin
    from Napa, CA
  8. Moal sells their torsion bar suspensions separately if you don't want their frame. Michael Moal recently quoted me $2,850 for the front or rear. Sounds like a lot but it is an engineered system. I have ridden in a car that they built and it is really worth the bucks if you have them.
    AHotRod likes this.
  9. designs that work
    designs that work
    Yes you can put sprint car torsion bars on a street car. With a solid rear axle 8", 9" it is fairly simple, with a I R S it gets a little complicated.
    AHotRod likes this.
  10. hotrod1940
    hotrod1940
    Built one in the seventies with sprint car stuff and it was really a cool ride and totally adjustable. 1940 Ford ch***is.
    AHotRod likes this.
  11. Devin
    Devin
    from Napa, CA
    What is the concensus of orienting the torsion bars in a horizontal fashion (as shown in the pics) versus a longitudinal manner?
  12. BCR
    BCR
    Was it the ride quality or the handling? How much better is it than a spring system?
    Just curious.
  13. Ride quality. I was not driving. It was very smooth and there was very little lean in the turns.
    I saw a Model A at the Tunica show with a home made torsion bar suspension. It had the bars parallel to the frame and the ends of the arms rode on pads welded to split original Ford wishbones.
    Schroder Racing (the same people who make the sprint car steering boxes) make torsion bars and they can size based on load and the length of the arm.
    AHotRod likes this.
  14. Devin
    Devin
    from Napa, CA
    I think that setup would be really cool. I would
    LIke to be able to set the torsion bars within the frame rails for a super clean almost skeletonized appearing suspension.
  15. designs that work
    designs that work
    These pictures are not very clear but they show the start of a torsion bar suspension using Toyota and Chevy luv torsion bars. More pictures in my albums. For ease of mounting torsion bar arms, in my opinion the rear bars would be mounted transversely or across the car. The fronts run parallel to the frame.
    AHotRod likes this.
  16. Degenerate
    Degenerate
    from Indiana
    As many torsion bars and stops I have left over from racing this thread has me interested.
  17. rooman
    rooman
    Steve Panaritis (aka The Greek) has being doing torsion bar frames for years here in Indiana and Lee Osborne was doing them before him.
    A coil spring is simply a torsion bar packaged differently but the advantage of correctly mounted torsion bars is that the spring base can be made wider and longer without having the coils hanging out in the breeze.
    Roo
    BigChief, Dapostman and AHotRod like this.
  18. oj
    oj
    Heres' the front end of one from the Jalopy Showdown a couple years ago
  19. 3wLarry
    3wLarry
    from Owasso, Ok
    no disrespect, but that don't look right hangin out in the breeze...coulda hidden it better me thinks...
    kidcampbell71 likes this.
  20. hugh m
    hugh m
    from ct.
    The springbase used to be a sort of critical item on old midgets, maybe they were after that...but on a hotrod hidden would be nice.
  21. sdluck
    sdluck
    Moal bros did a car for I think Alen Ness and the front bars were long ways,very nice car.
  22. Speedwagen
    Speedwagen
    I'm putting a ford rear end in a sprint car ch***is for a street rod.
    It's not as easy as I first thought...I think it will be a four bar with the rear torsion arm mounted with a shackle to allow some motion. Any advise from somebody that's done it?
  23. Can they work, sure. Just have to get the rates right on the bars.
    Check my my build thread in my signature. There are some pictures of my ch***is about 1 or 2 pages back from the last page of the thread. Real clean torsion bar install on all four corners.
  24. gasserjohn
    gasserjohn
    few years ago in a radir wheel add was a photo of HellzaPop'n coupe the cleaness /simple torsion bar setup /like on front ends of fed dragsters
    will look for photo if no one else posts it
    would like to see details
    AHotRod likes this.
  25. .
    I got on my computer and have a few minutes to post some pics before work. Here is my ch***is being built by JoKerr Fabrication. Jo has built and raced sprint cars and that is apparent in the design of this ch***is. Torsion bars front and rear with a nice clean install.
    I hope these help you with some ideas.
    The rear set up:
    The front:
    Jo is fabbing the torsion arms to tuck up behind the V8-60 Axle I'm using like the paper pattern on the driver's side shows.
    Most of these pics were taken last week right before the ch***is was blown apart for paint. The completed car will be on display in the ba*****t at the Detroit Autorama which starts on March 8th. If anyone out there is going, stop by and say hello.
    Here is a pic of the body that will be wearing a nice shiny coat of black very soon.
    AHotRod likes this.
  26. gnichols
    gnichols
    from Tampa, FL
    Thanx, it sure has. I've been sub'd to your build for just that reason! Gary
  27. Speedwagen
    Speedwagen
    View attachment PICT0594 (1).pdf
    This is close to how my 9" is hooked up now, but I think it needs a shackle on the torsion arm to allow things to move as the suspension travels up and down..any thoughts? :confused:
  28. fossilfish
    fossilfish
    from Texas
    A coil spring is nothing more than a torsion bar twisted in a coil. Both are just twisting steel. The cool deal about a torsion bar is the easy ride height adjustment.
  29. Rootie Kazoootie
    Rootie Kazoootie
    from Colorado
    Yes, you need to free up the torsion arm, there's a lot of bind going on in that setup.
  30. 2OLD2FAST
    2OLD2FAST
    from illinois
    Perhaps the setup has a slot in the arm instead of a round hole ?
    dave
