tech tip needed: Easy grind MIG wire
Discussion in 'The Hokey Ass Message Board' started by briggs&strattonChev, Dec 9, 2003.
  1. briggs&strattonChev
    briggs&strattonChev
    Hey, has anyone used easy grind mig wire? I guess its supposed to let the beads grind off easier, but ive heard that it isnt as strong. Ive never used it. Is it strong enough for body work? Is it worth it? Any tips would be appreciated........................Briggs
  2. Unkl Ian
    Unkl Ian
    ESAB. Plenty strong for bodywork. I thibk it's more expensive than regular wire.
  3. It's good stuff for sheet metal but it is NOT for structural welding. I don't think there is a huge price difference.
  4. Blownolds
    Blownolds
    from So Cal
    Tech tip on the above mentioned area: use beveled flap sanding wheels instead of hard grinding wheels. Choose your grit carefully.
  5. briggs&strattonChev
    briggs&strattonChev
    [ QUOTE ]
    [/ QUOTE ]
    does it grind off THAT easily? Grinding wheels are too course? Also, does it melt easier so a different amp setting would be needed?
  6. [ QUOTE ]
    [/ QUOTE ]
    I keep hearing this. I guess I'd better try them. I've always taken mig beads down with a 3"X1/4" stone on my die grinder.
  7. briggs&strattonChev
    briggs&strattonChev
    ive always used 4 1/2" stones on an angle grinder, way outta the question for easy-grind I take it?
  8. I didnt see that it was real easy to grind. maybe a tad better -but not that much.Cant really remember the brand-seems like it was "american wire" or something.......
  9. Shiva69
    Shiva69
    the company that makes the wire is
    ESAB its called easy grind wire and is only available int .023 dia.
    if you have Airgas local they can order it for you.
    I have not used yet... but have some on order. but the stuff as i understand it dosn't need a grinding wheel just a flap wheel... probably 60 grit to keep the heat down.
    Garth
