Hot Rods Late 31 Ford Truck CHOP & CHANNEL !
Discussion in 'The Hokey Ass Message Board' started by Flop, Jun 10, 2012.
  1. gerry miller
    gerry miller
    Thanks Flop, Enjoy your No BS builds.:D
    Gerry
  2. jimz31
    jimz31
    from PA
    This just keeps getting better!
    Awesome work! Thanks for sharing!
  3. jimz31
    jimz31
    from PA
  4. Flop
    Flop
    thanks again gerry!!
    glad you are liking it Jim!!
    a pillars
    nice gaps always help things out !
    tig and file tig and file
    and weld weld weld weld
    kidcampbell71 likes this.
  5. Flop
    Flop
    back of the truck is finished up as far as the chop is concerned !
  6. LOPESphotographics
    LOPESphotographics
    One step closer
  7. tobyflh
    tobyflh
    from Peru il
    Sweet. love the work you do.
  8. flop you do some real sanitary looking OEM mods!! i love your style and taste!
  9. Flop
    Flop
    CLoser by the day on this one Chris !
    thanks Toby!!
    prime I appreciate it !! i like to keep things super tasteful and clean if you couldnt tell !!
    gaps on the door. tight tight tight joints make your life easier!
    chops done ! better pictures once i hit it all with 80 grit
  10. ss34coupe
    ss34coupe
    Coming along nicely. Good work!
  11. Nice work as always
  12. deadendcruiser
    deadendcruiser
    Just keeps getting better, awesome work. What metal working tools are you using when you form your patches?
  13. jimz31
    jimz31
    from PA
    Fantastic work!! (as always!)
    Thanks for sharing Flop!
  14. Flop
    Flop
    thanks 34 coupe !
    thanks taildraggin!!
    dead end thanks!! using a bead roller ,english wheel and shrinker stretcher .
    thanks you Jim ! see ya soon!
    well we are kicking around the idea of sweeping the body line in the cowl up ward.
  15. 31ster
    31ster
    I like it, maybe someone with a better eye will make a suggestion but to me it's good
  16. That's a nice subtle touch on the line change Flop.
  17. VoodooTwin
    VoodooTwin
    from Noo Yawk
    I like the sweep, a lot. It marries up nicely with the curve in the cowl. Gives the truck a more elegant look. And if you're Z-ing the frame in front, it could marry nicely with that too.
  18. 31ster
    31ster
    Im still not sure exactly how i am going to do the frame, my roadster was z'ed in the back with a dropped axle in the front and I really liked how it sat, I want this one lowered but not real low. I will prob give it some rake with the tire choice also
  19. Flop
    Flop
    thanks spdjnky! its not to noticeable up close ... you are gonna see if from 10 feet away thats what i like about it !
    thanks voodoo !
    i def think it adds to the truck Ian!
  20. Flop
    Flop
    inner structure made!
    and attached !
    never to be seen again !
    riveted in
    and what shes gonna look like !
  21. Flop
    Flop
    allll about fit!
    not welded
    welded in
    now the part i was super excited about !!
    and shes done !
  22. DAVEO!
    DAVEO!
    Awesome work!!!
  23. jimz31
    jimz31
    from PA
    Now that is a tight fit!
    Just when I think you are done amazing me you pull this off!!
    I can't wait to see what you have in store for the 31!!
    Great work as always Tom!!
  24. jimz31
    jimz31
    from PA
  25. shoebox1950
    shoebox1950
    Beautiful work, Flop and I love that sweeping lower cowl bottom!
  26. lowpunk
    lowpunk
    from berwyn, il
    damn, thats looking killer man! YOur work and quality is always amazing! I'm really really digging that slooped from cab piece!
  27. Corn Fed
    Corn Fed
    I normally cry when I see someone channel a car because they usually hack it all up. But not this time. The job you did is exactly how it should be done. Good job. With fenders on it, it is going to really stand out.
  28. Flop
    Flop
    thanks daveo!
    cant wait jim!!
    thanks Mr Radcliffe!
    appreciate that lowpunk!!
    thanks corn fed ! i always cringe when i hear channel as well! Mainly because it is a ton of work that most people generally skip and make up with loads of square tube and b/s welds to the body !
    and the back of the cab is pretty much ready to go !
  29. RUSTALOT
    RUSTALOT
    from GA.
    Great work! cant wait to see more of the 31.
  30. barrnone50
    barrnone50
    from texas
    Flop you have the Eye for detail!! and the skills to make it happen. Sure like what you did on the lower cowl!! Great Job!!
