help removing wiper base - 51 chevy car
Discussion in 'The Hokey Ass Message Board' started by garagebuilt51, Feb 1, 2013.
  1. garagebuilt51
    garagebuilt51
    I got the wiper arms off. i cant get the bases out now. i pulled the nut and clamp from under the dash. where do they disconnect? every joint i see, the pin is flared and would need to be drilled to disconnect. thanks
  2. 325w
    325w
    Could have been sealed real good. Picture?
  3. cosmic12
    cosmic12
    Did you disconnect the arm from the wiper motor? Mine came out with the arm connected and it is a pain in the **** getting it all routed around the chit under the dash.
  4. davidbistolas
    davidbistolas
    Yup comes out with the transmissions attached, and it's a ***** to do.
  5. garagebuilt51
    garagebuilt51
    ok ill look again thanks
