1950 Chevy quarter window quandry
Discussion in 'The Hokey Ass Message Board' started by thetwistedpiston, Feb 3, 2013.
  1. thetwistedpiston
    thetwistedpiston
    I have a 1950 Chevy Styleline Deluxe that has (had) the sliding quarter windows. I would like to change to the fixed windows. I have gl*** that came from a car with fixed windows and would like to know if all I have to do is buy the rubber for the fixed windows or is this swap even possible.
    If push comes to shove I'm sure I can fab up some sort of mount and make it work. I was hoping for an easy swap.
    ...any insight would be appreciated.
    »Keith
  2. dorf
    dorf
    from ohio
    is it the cpe in your avitar, if it is my olds is a cpe with fixed quarter gl*** and all it has is the rubber and the garnish molding holds it in . should be the same window .
  3. thetwistedpiston
    thetwistedpiston
    Yes, same as in the avatar. I was looking at Chevy of the 40's and they show a couple different fixed window rubber, I'll have to take a look and see if I can figure out what the difference is. Perhaps the size of the gl***. Thanks for the reply, I guess I can order the rubber and see how it goes.
  4. 1953girlracer
    1953girlracer
    from Redlands
    Any good gl*** guy will have the rubber moulding for you to buy
  5. GREASER815
    GREASER815
    Got any more pictures of that rig? I like it!
  6. 325w
    325w
    Not sure if will help you are not. The tri 5 Chevy utility sedans that had the fixed 1/4 gl*** just had a couple of clips that were held with a screw. Then the garnish molding held the gl***.
  7. thetwistedpiston
    thetwistedpiston
    Thanks I"ll look into that.
