converting inches to AN
Discussion in 'The Hokey Ass Message Board' started by Gearhead Graphics, Feb 4, 2013.
  1. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    I need to run some AN tubing/hose for my fuel system. My previous fittings are 3/8 and 5/16. Would it be -8 AN that would fit these?
  2. WGaryOliver
    WGaryOliver
    AN = size in 1/16"
    1/4 = -4
    5/16 = -5
    3/8 = -6
    1/2 = -8
    etc
  3. Johnny Gee
    Johnny Gee
    from Downey, Ca
    1AN = 1/16 of an inch.
    As in - 8an= 8/16, or 1/2.
  4. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    OK, thanks guys. 8 was suggested to me, glad I didnt order before checking on how to convert! looks like 6 is my ticket.
  5. oldtom69
    oldtom69
    from grandin nd
    the dash number is the size in sixteenths= dash 6 is 6 sixteenths or according to jr high math=3/8's.5/16 would be -5 which is not very common,but can be found.dash 8=8/16's[1/2 inch] and so on
  6. Rock Island Rocket
    Rock Island Rocket
    -6 is 3/8, -8 is 1/2 and i think -4 is 1/4 and 5/16
  7. oldtom69
    oldtom69
    from grandin nd
    man I'd be dead last in the typing drags
  8. BigPerm365
    BigPerm365
    -4 is 1/4"...-5 5/16"...-6 3/8'...-8 is 1/2".
    Be advised, "AN" flare is 37-degrees....SAE is 45-degree. You cannot inter mix these seat angles.
    Most all AN hot rod stuff is aluminum. SAE is steel & br*** @ 45-degrees. Now to really confuse you; "JIC" is also 37-degree, mostly in hydraulics ( industrial ) and fittings are steel.
    If you're plumbing w/ braided stainless..use the Earls or whatever. However, in hidden
    places you can use Stratoflex, Parker, or Gates or other truck shop style re-useable fittings & hose at a reduced cost. IE; hidden oil pressure lines, fuel lines,etc. The low-pressure fabric-wrapped, 2-wire hose is cheap.
    Don't overtighten aluminum AN...or they will "gall" upon taking back apart.
    Good luck
  9. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    Going to do the "push loc" stuff whith a nylon hose. Not going far, from the factory location fuel tank to the back of my motor in my 61 f100, but need to run stuff that can handle pressure.
    Thanks for the tip on the degree of the flare, that could have made a mess
  10. Make sure you use hose that is designed for Push-Lok fittings. Regular fuel line won't cut it! Earl's Super Stock hose will work with push-lok ends. I try to stay with Parker hose when possible. I figure if they invented the stuff, it ought to be pretty good... Parker also offers a lot of colors of hose, so you can "code" the plumbing by what fluid is running through it.
  11. safari-wagon
    safari-wagon
  12. Sorry to disagree, but I've used Parker Push-lok for the fuel system on my Methanol fueled supermodifieds for over a decade. The hoses hold up just fine on straight Methanol, so I wouldn't see E15 gas being an issue...
  13. <TABLE border=0 cellSpacing=0 borderColor=#ffffff width=900><TBODY><CENTER><TR><TD height=100 width="100%">
    AN (Army-Navy) Fitting Thread Size Chart
    <CENTER><TABLE border=1 cellSpacing=0 borderColor=#000000 width=400 bgColor=#ffff00><TBODY><TR><TD width="25%">
    AN Size
    </TD><TD width="25%">
    Hose Size
    Thread Size
    </TD></TR><TR><TD width="25%" align=center>-3</TD><TD width="25%" align=center>3/16</TD><TD width="25%" align=center>3/8-24 SAE</TD></TR><TR><TD width="25%" align=center>-4</TD><TD width="25%" align=center>1/4</TD><TD width="25%" align=center>7/16-20 SAE</TD></TR><TR><TD width="25%" align=center>-6</TD><TD width="25%" align=center>3/8</TD><TD width="25%" align=center>9/16-18 SAE</TD></TR><TR><TD width="25%" align=center>-8</TD><TD width="25%" align=center>1/2</TD><TD width="25%" align=center>3/4-16 SAE</TD></TR><TR><TD width="25%" align=center>-10</TD><TD width="25%" align=center>5/8</TD><TD width="25%" align=center>7/8-14 SAE</TD></TR><TR><TD width="25%" align=center>-12</TD><TD width="25%" align=center>3/4</TD><TD width="25%" align=center>1-1/16 SAE</TD></TR><TR><TD width="25%" align=center>-16</TD><TD width="25%" align=center>1</TD><TD width="25%" align=center>1-5/16 SAE</TD></TR><TR><TD width="25%" align=center>-20</TD><TD width="25%" align=center>1-1/4</TD><TD width="25%" align=center>1-5/8 SAE</TD></TR></TBODY></TABLE></CENTER>
    </TD></TR><TR><TD style="LINE-HEIGHT: 100%" width="100%">
    "NPT" (National Pipe Thread) Thread Size Chart
    <CENTER><TABLE border=1 cellSpacing=0 width=300 bgColor=#00ffff><TBODY><TR><TD align=center>Pipe Thread</TD><TD align=center>Threads per Inch</TD><TD align=center>Inside Dia.</TD></TR><TR><TD align=center>1/8</TD><TD align=center>27</TD><TD align=center>1/8</TD></TR><TR><TD align=center>1/4</TD><TD align=center>18</TD><TD align=center>1/4</TD></TR><TR><TD align=center>3/8</TD><TD align=center>18</TD><TD align=center>3/8</TD></TR><TR><TD align=center>1/2</TD><TD align=center>14</TD><TD align=center>1/2</TD></TR><TR><TD align=center>3/4</TD><TD align=center>14</TD><TD align=center>3/4</TD></TR><TR><TD align=center>1</TD><TD align=center>11-1/2</TD><TD align=center>1</TD></TR></TBODY></TABLE></CENTER>​
    </TD></TR></CENTER></TBODY></TABLE>​
  14. Nylon hose
    Late model stuff
