Who has a Gasser style car ? Stand up and be counted !
Discussion in 'The Hokey Ass Message Board' started by AHotRod, Feb 9, 2004.
  1. topchopvalle
    topchopvalle
    Heres mine! -65 Valiant. Frontwheels stretched 4" Rear moved forward 12"
    Enginesetback? 25" to crank centerline. 498 cuin Mopar stroker/720HP on gas,
    Now adding twin toilets and metanol!
  2. langy
    langy
    A/FX then, a g***er has a stock wheelbase
  3. icody
    icody
    Here is my G***er Project...its just another 1957 Chevy G***er...
    Love Then G***ers!!
  4. topchopvalle
    topchopvalle
    A/FX it will be then!
  5. Hamtown Al
    Hamtown Al
    Here's mine in 1959 and in 2012.
  6. Baron
    Baron
    My latest wallpaper picture. Helps me forget about the 2 ft of snow outside in the yard(although it is melting fast). Hopefully spring is right around the corner.
  7. Butch M
    Butch M
    Man Baron every time I see this car I love it more
  8. Willy_P
    Willy_P
    Baron,
    What size wheels and tires are you running? The photobucket pics are very cool!
  9. 1933t
    1933t
    from Buffalo NY
    Good pics !!!!
  10. Baron
    Baron
    205/75-15’s front on 15 x 4's with 315/60R-15 Hoosier drag radials on the 10 inch Cragars.
    Thanks Butch.
  11. Cortney
    Cortney
    Yabba Dabba Doo!!
  12. hotrod--willys
    hotrod--willys
    My 40 Stude mild g***er. 383ci in 671 Blown sbc.;)
  13. AHotRod
    AHotRod
    Where can I see more pictures?
  14. 1971BB427
    1971BB427
    from Oregon
    Here's my present build. Just drove it Monday for the first time since purchasing the stock '63 Falcon in March. Whirlwind build, and lots of little things to still do, but at least it's driveable now!
    1963 Falcon Futura with 464 BBC, Edelbrock heads, Super T10 four speed, 8.8" Ford rear, ET mags, 10" Hurst slicks.
  15. AHotRod
    AHotRod
    Enjoy what G***er's are all about!
    Glenn
    <IFRAME height=315 src="//www.youtube.com/embed/OLtnqPb0jWQ" frameBorder=0 width=560 allowfullscreen></IFRAME>
  16. Baron
    Baron
    Nothing like that first ride. Looks tuff. Nice job. Love these early Falcons done up this way.
  17. 1971BB427
    1971BB427
    from Oregon
    Thanks Baron! It's back in the canopy for a few winter project upgrades!
  18. artful dodger
    artful dodger
    i'll through my truck in the mix…
    still a long way off but getting there.
    it's a 1940 dodge with a 270 and a A-833 4 speed OD
    i am currently working on getting the 4-71 supercharger installed
    it will be v belt driven.
  19. OahuEli
    OahuEli
    from Hawaii
    Thanks! Brought back some good memories of my childhood. Quain put it in just the right perspective. The G***ers and Fuel Altereds were my favorite cars back then, in part becuse of the wheelstands and "all over the track" handling. Always a great show.
  20. 1971BB427
    1971BB427
    from Oregon
    Exactly! I grew up in the 50's and as a young teen in the 60's it was exciting to see those cars make runs. The fact they didn't go perfectly straight, and tended to stand up on the rear bumper just made them more appealing!
  21. Animal
    Animal
    Looking through this thread, I realized that I never posted a picture of my g***er-inspired '56 Plymouth after it was "finished". :) 440/TF727, six-point cage, homebuilt fenderwell headers, tube bumpers, radiused wheelwells with 10" US slots on the back, ET five-spokes on the front. I drove it the 700 miles to Joplin for the HAMB Drags, had a freakin' blast! The car is now in the Netherlands.
  22. micky69
    micky69
    from Ohio
  23. Scottrodsllc
    Scottrodsllc
    from ohio
    My all Gl*** Henry J, Serial number 1
    Now being converted into my AA/GS Drag car.
    Scott
      82.3 KB
  24. 69z
    69z
    Work in progress. Gonna take some time.:)
  25. AHotRod
    AHotRod
    Now that is a very cool looking ride, well done!
  26. abone1930
    abone1930
    My 35 panel Im building :D
  27. marks73turbota
    marks73turbota
    I've had my G***er style '63 Catalina on here in its build stages. Well I'm still building it. This is the last and final engine configuration. With the finished but not started engine all in place. I'm a turbocharger nut so I had to incorporate that into this build so it is not even close to traditional. But much of the ch***is and body mods are older style G***er like. 1960 389 punched .090 to 406. KRE D-Port aluminum 320 cfm heads. Solid roller turbo cam. Ross dished pistons on GRP aluminium rods, forged Ohio 3.75 crank. Wenzler Gutsram Tunnel Ram with twin blow thru E85 750s, twin 76MM Turbonetics ball bearing tuebos blowing thru twin intercoolers.
    Ford GM spec (Dearborn) top loader 3 speed, ladder bar rear suspension, Ford 9 inch detriot locker 35 spine axle 3:50 geared rear end. '57 Chevy pickup front beam axle on custom front frame clip.
    Engine moved back 11 inches and firewall cut and reformed around that.
    Engine compartment.
    Towed it to a local cruise last October, full car pic.
    This is my concept to fit my needs and wants. Nowhere traditional but with traditional flavor. Hope to start it up soon. Just needs wiring run, fuel system finalized, and coolant lines run from trunk mounted radiator to the front.
    Mark L
  28. 1971BB427
    1971BB427
    from Oregon
    Very impressive Mark L! :)
  29. 1971BB427
    1971BB427
    from Oregon
    My Austin g***er has been sick with a bad engine. Almost finished installing the replacement I've built for it. Just waiting on a pair of vintage Mr Gasket finned valve covers to arrive, and plumbing to the twin 600cfm Holleys.
    Had to work up a little bracket after changing from tunnel ram to cross ram so the Hilborn scoop would still supply fresh air to the carbs.
