'61 pontiac bubbletop
Discussion in 'The Hokey Ass Message Board' started by Hyde_Auto_Body, Feb 5, 2013.
  1. Hyde_Auto_Body
    Hyde_Auto_Body
    I recently picked up a '61 Pontiac bubbletp with a 389 and an automatic. I don't have a whole lot of experience with pre-65 pontiacs and I was wondering if anyone knew if I could bolt a late 60's turbo 400 up to this engine and what would have to be done to do so.
  2. Hotrodbuilderny
    Hotrodbuilderny
    With an adapter, the early Pontiac starters bolted to the bellhousing the later ones bolted to the block
  3. Rocky
    Rocky
    Classified Editor
    Not without a ****** adapter...In 1964 the bolt pattern changed and the starter was attached to the block in '65....some 64 blocks are drilled for the block-mounted starter also.
  4. Hyde_Auto_Body
    Hyde_Auto_Body
    Who sells the adapter?? Will a flexplate compatible with the turbo 400 bolt up to the earlier 389 crank?
  5. Hotrodbuilderny
    Hotrodbuilderny
    There are a few companies out there Nunzi I am pretty sure has one, Bendtsens is another and there was another that escapes me at the moment,I am pretty sure it's Wilcap.
  6. slammed
    slammed
  7. swe64
    swe64
    i put a berdsen adapter on my 1962 catalina and kit included flexpate and starter i use a chevy th 700 trans but adapter is drilled for bop battern allso.there is a good magazine article on berndsen homepage allso a 62 cat
  8. stuart in mn
    stuart in mn
    Which model is your car? Catalina, Ventura, Bonneville? The Catalina and Ventura transmission tunnel was a little bit smaller than a Bonneville; in order to fit a TH400 you'll probably need to do a little hammering in the tunnel in spots to get it to fit.
  9. ????...?
  10. xketh
    xketh
    from New York
    You need a butler adapter plate if you use the 61 389 for the starter. that's pretty much it besides the drive shaft.
  11. models916
    models916
    Might me cheaper to get a later model engine and trans combo. Lots of 400/455 trans ams out there.
  12. Rocky
    Rocky
    Classified Editor
    No. not sure about the offset but the flex plate for a 61 Pontiac was never drilled for a 350 or a 400 turbo torque converter. In 1963 Pontiac increased the center hole diameter of the flex plates/flywheels also. I'm told the crank flange bolt pattern is the same for all Pontiac V/8 engines.
    I've always wondered if a guy may be able to redrill a stock 61 flex plate [either a slim-jim or a hydro] to accept a 350 or a 400 torque converter...dont' know without trying.
    If you buy the Bendtsens kit, you won't need to worry about it.
  13. black 62
    black 62
    from arkansas
    that is a really attractive body style---cograts
  14. Rocky,
    The Slim Jim had an actual flywheel with a cushioning center plate attached to it..I can't remember what the Bonneville Hydramatic had.
  15. Rocky
    Rocky
    Classified Editor
    ..........and there's the question of if the later 350/400 converter will register in the 61s crank.
  16. swe64
    swe64
    61-62 crank is not same as 63 and newer. trans dont matter what trans it is on.
    butler adapter you need to use 65 or newer flexplate(th 400-350) on my steel adapter it stamped berdsen as manufactuer. berdsen sells a kit with auluminium adapter allso.
  17. Hyde_Auto_Body
    Hyde_Auto_Body
    I decided to swap out the whole driveline with a 1973 455 and TH400.
  18. slammed
    slammed
    PIX or the car is a phantom.
  19. I don't know about the e.t. predictions yet.
    We don't even know if this is a Cat or a Bonneville, that will be several hundred pounds heavier.
    Even a Cat street car will be close to 2 tons.
    Solid mid 12's with a low comp. 455 will require a 3.5 to 4.0 gear in the rear, and at least a 2800 converter..
    Not sure that the o/p has this in mind .
    That being said...13 .90 's would be easily attainable ..even with 3.08 gears
  20. belair
    belair
    Need some pics. I love all the bubbletops.
  21. NHRA has it at 3679 , but a real street driver will be a couple hundred more.
  22. Hyde_Auto_Body
    Hyde_Auto_Body
    Nope not a phantom just not very pretty to look at I guess which is why I never posted a pic. It's a Catalina. Really rusty but runs. The short term goal is to be able to run low 12's. After that maybe a straight axle. Don't know yet.
      427 KB
  23. Hyde_Auto_Body
    Hyde_Auto_Body
    posting some more pics. Like I said the Catalina is really rusty so a lot of the sheetmetal needs repalcement. Picked up a set of VFN fenders off the HAMB and will get the VFN hood, doors and deck lid. I'll omit the front bumper. The car has manual steering and brakes. No A/C. Will retain the original interior.
      430.3 KB
      438.2 KB
      447 KB
      482.2 KB
  24. slowmotion
    slowmotion
    Always been a bubbletop fan. Gonna take some serious grunt to get that beast into the low 12s. From your avatar, looks like it's not your first rodeo though. Great start & good luck with it.
  25. jfreakofkorn
    jfreakofkorn
    oh thats nice ...
    i would freshen up the engine n interior and leave the outside the way it is ... IMO
  26. slammed
    slammed
    Patch the floor, put it on the road! Then tear it down for that resto-rod/paint/body/ect.
  27. jesse1980
    jesse1980
    x2....
