Looking for the best brake line tube cutter tool, tired of the cheap ones at Napa
Discussion in 'The Hokey Ass Message Board' started by 55Thunderboy, Feb 8, 2013.
  1. 55Thunderboy
    55Thunderboy
    from NYC
    I must have 4 cheap brake line tube cutters in my box and they **** especially after making a few cuts in stainless.
    I want to buy the BEST cutter money can buy so i have it for life. No questions asked on this because have a **** tool just ruins the day with frustration
    Can any of you guys suggest a name brand cutter or what i should be looking for?
  2. chigger
    chigger
    Rigid tubing cutters. great tools with replaceable cutter wheels.
  3. tikiwagon13
    tikiwagon13
    I've had my MAC Tools racheting tube cutter for 17 years, still works great!
  4. brian55lvr
    brian55lvr
    from ma
    yup---id do either one of those---or a snap-on cutter
  5. 55Thunderboy
    55Thunderboy
    from NYC
    Guys is the Rigid a tool i can grab at Home Depot? Can any of you guys throw up a photo? I would like to have a tool with replaceable cutting wheels. How do those ratcheting ones work?
  6. HOTRODPRIMER
    HOTRODPRIMER
    I probably have 5 cheap tubing cutters that have been regulated to the junk drawer of my tool box.
    I now use a Rigid #15 tubing cutter a good friend gave me for my Birthday,,I told him "Thank you,but I have several tubing cutters".
    His replied,"Yeah,I know but after using yours I decided you needed one that works!
    I honestly didn't give it a thought as far as a inexpensive tool is concerned to accomplish it's seldom use,,And if the wheel ever stops cutting crisp and cleanly,I have 2 replacement wheels.
    I will never need another tubing cutter and if a neighbor want's to borrow on,,I have a several in the aforementioned junk drawer!:D HRP
  7. 55Thunderboy
    55Thunderboy
    from NYC
    Thanks where can i grab one of these?
  8. HOTRODPRIMER
    HOTRODPRIMER
    I believe you can get them at ace hardware,,they are about 30 bucks. HRP
  9. rat nasty
    rat nasty
    Any good hvac supply house carries a good quality set of tubing tools
  10. for brake/fuel lines i use a Ridgid #10
    i've had it for so many years....maybe 30? goes to show if you buy quality tools they will last a lifetime or two
  11. the-rodster
    the-rodster
    What about a flaring kit? I've went thru several of the 30-40-50 dollar ones.
    Rich
  12. 55Thunderboy
    55Thunderboy
    from NYC
    Guys i was looking just now at the Rigid it mentions it being rated copper and aluminum not stainless line, does it matter and does stainless kill the cutter wheels?
  13. 55Thunderboy
    55Thunderboy
    from NYC
    Rich i got the new Eastwood kit its awesome il never use the other **** in myntoolbox again. Im so happy with the new flare tool
  14. HOTRODPRIMER
    HOTRODPRIMER
    Certainly stainless is harder and will wear out a cutting wheel,,Personally I use regular brake line tubing from Napa and if I need to shorten a piece I use the rigid cutter and my SK Double Flaring tool.
    I tend to think of stainless tubing as something that you use under the kitchen sink. :D HRP
  15. gmc1941
    gmc1941
    HVAC supply house have available Stainless Steel cutting wheels for quality (imperial) cutters.
  16. F-6Garagerat
    F-6Garagerat
    I use the small Imperial "the imp" and its never let me down. Had it since 1987. So small you can hold it in the palm of your hand. ImageUploadedByTJJ1360342619.008266.jpg
  17. gearheadbill
    gearheadbill
    I used to do a lot of SS brake lines/fuel lines and I found that the easiest way to cut the tubing was either vertical band saw or die grinder-cutoff wheel. The end of the line to be flared needs to filed-sanded-ground perpendicular to the tubing any way. If you don't get the flared end exactly 90 degrees to the tubing run it will leak. The line also needs to be de-burred on the I.D. and O.D.. For me it was just easier. Running nice LEAK-FREE SS lines is hard work and takes time and patience. I don't have either anymore.
  18. Carter
    Carter
    After using every combination of ****py cutters, flaring tools, etc. for many years, I finally have a set up now that works like it should. Mastercool hydraulic flaring tool, a small Ridgid tubing cutter like the imp pictured above, a small flat file, and a tapered deburring tool.
    Makes brake line work much easier and less frustrating.
    Sent from my DROID device using the TJJ mobile app
  19. ^^^ yep, they make a pretty good double flair tool as well.
  20. chigger
    chigger
    most Rigid cutters #15 and above carry and extra wheel under the handle retaining screw
  21. fsae0607
    fsae0607
    Ridgid brand cutter and tapered reamer here. Also use the Eastwood flare tool. Never had a problem.
  22. Uncle Phil
    Uncle Phil
    As carter said the Mastercool hydraulic set looks like the cats ***, but I've never used one. 71475 is the part number.
  23. Yo Baby
    Yo Baby
    The ss will wear out wheels for a fact but more important than that,,,the flaring tool needs to be the real deal and I don't know if Rigid makes one for Stainless or not.
  24. Deuce Roadster
    Deuce Roadster
