Lowering 51 Chevy Truck
Discussion in 'New to the H.A.M.B.? Introduce yourself here!' started by ebgb51, Sep 14, 2005.
  1. ebgb51
    ebgb51
    from ALAMEDA,CA
    Hey Guys Got A Que.
    Universal Lowering Kits Are Way To Big For My 51 Chevy Truck
    Rear End.
    Everything Is Stock, But The U Bolts Are Real Skinny.
    Should I Have Some Ubolts Made And Use 2x4 Steel Tubing
    I Heard That Works.
    Any Help Would Be Much Appreciated.
  2. elwood blues
    elwood blues
    if you got a torch you could just heat up the springs a little bit and take some of the arch out of them the big problem with that is getting both sides right. another thing you could try is takeing out a leaf or two and getting your spring rebanded
  3. burger
    burger
    Your truck has 1-3/4 wide springs right now (at least my '54 3100 does). If you change the "lower shock mounting plate" (Speedway Link) to one with wider spacing (like for 2-1/2 wide springs), you can use whatever blocks you want.
    Ed
  4. ebgb51
    ebgb51
    from ALAMEDA,CA
    thx to all for your help. sorry i posted in the wrong location.
    im new.
    ill give your comments a try and see which works best .
