Need help on a 54 Chevy exterior door handle
Discussion in 'The Hokey Ass Message Board' started by HellzBelle54, Feb 8, 2013.
  1. HellzBelle54
    HellzBelle54
    from FL
    Hey Guys,
    I have searched the forum a few times but have come up empty.
    Can anyone help me out on how to remove these outside handles so I can get some keys made?
    I appreciate any help in advance.
  2. aaggie
    aaggie
    Take the door panel off and look at the clip and screw that holds it on. Remove from the inside.
  3. Jkustom
    Jkustom
    On the door jam part there is a tab thingy you have to slide out. It clips the handle to the door. If I'm thinking of the right car. Been a while since Ive shaved my handles..
  4. jcmarz
    jcmarz
    from Chino, Ca
    Just like mentioned above^^^^^^^^^^^^there's a clip on the jamb. Use a screwdriver to pry it away from the jamb and then a get some pliers and pull it completely out.
  5. HellzBelle54
    HellzBelle54
    from FL
    Yeah I was thinking it was the clip in the jam...is there a certain tool to remove it or just the ole trusty flathead?
    The panel is already off and I didn't see anyway to remove it from inside...there are two screws that hold the locking mechanism in but I don't know if that will allow me to remove the handle or not.
    Thanks for the responses guys.
  6. Jkustom
    Jkustom
    yeah a flat head, or anything you can get in there to pry it out a ways..
  7. BJR
    BJR
    The clip may be behind the rubber weatherstrip.
