Outlaw Performance fiberglass body
Discussion in 'The Hokey Ass Message Board' started by panhead1961, Feb 9, 2013.
  1. panhead1961
    panhead1961
    Just checking to see if anyone has an Outlaw Performance car or know of someone that is building one? I have a few questions..
    Thanks:confused:
  2. Moedog07
    Moedog07
    People on here will tell you that fiber gl*** bodies are NOT old school but GM was building them in the 50's...
  3. panhead1961
    panhead1961
    I've had both....... just happens fibergl*** is what I have now.
    Thanks
  4. Ha ha!!?? Yeah. Old School and ****.
  5. HOTRODPRIMER
    HOTRODPRIMER
    I've know several guys that have built them in the last 20 or so years.
    as far as Gl*** body's go they were pretty nice. HRP
  6. panhead1961
    panhead1961
    Thanks Hotrodprimer... I have heard good things about Outlaw and they have been VERY helpful on the phone!
    This car was built in 1998 and never been on the road. Roger Ausley from Ausley's Chevelle ordered the car and it was sold a few times before I found it. Most of the parts were with it except the grill shell and some other small stuff. I think it will make a decent car when done.
  7. Fenders
    Fenders
    I guess a 55 Corvette is ****?
    Panhead that looks pretty nice.
  8. panhead1961
    panhead1961
    Thanks Fender!!
  9. carlos
    carlos
    from ohio
    Built one ,3 window,tough as nails,you will be very pleased,One thing bout a gl*** car when its done it will look nice along time,not worth as much,but makes a good hot rod.Outlaw bodies have a tag in the gelcoat on the driver side up under the cowl on the inside .
      6.3 KB
  10. brigrat
    brigrat
    from Wa.St.
    I have done 2 of their Willys body's #24 & #25, great people to deal with, nice gl*** body's. Only complaint were the door hinges, to weak so we built our own. As with any gl*** body I reinforce the inside of all fender lips to give them more strength and feel.
  11. panhead1961
    panhead1961
    Thanks Carlos
    Having a tuff time getting the PW in the doors. The car was ordered without them installed. I can't seem to find the right u channel gl*** run. Ordered a different size last week, hope it works.
  12. panhead1961
    panhead1961
    Thanks brigrat... good tip on the fenders! NICE looking car!
  13. HOTRODPRIMER
    HOTRODPRIMER
    I have had steel body's and gl*** and have been building early styled Ford cars since the mid 70's.
    I've had 2 Gibbon gl*** bodied cars, a 32 3-window,a 39 Ford convertible and Westcott 32 Roadster and I enjoyed each and everyone of them.
    Your always going to have the Richard Cranium Gl*** hatters that have to tell you your car don't measure up to their standards,,don't sweat it!
    Whenever I was asked if my roadster was steel or gl***,I asked them can't you tell?,,they usually consider themselves experts.
    My roadster ain't real steel but it sure was real fun! HRP
    NJ Don likes this.
  14. Who cares? That's what I was saying. I've seen plenty of okay gl*** cars.
  15. HOTRODPRIMER
    HOTRODPRIMER
    Adding one of the :) or :D at the end of the sentence helps project the intended meaning. HRP
  16. Right. Ha ha
  17. panhead1961
    panhead1961
    Right Crash....That's what I think. I like both steel and gl***. I had a sweet orig body
    32 Plymouth PB 3 w rumble seat car. Loved it! Had a gl*** 32 Ford 3w hiboy made by a guy in Tennessee but never got it on the road, sold it. I hope to drive this one!
  18. redhumphries
    redhumphries
    the problem with gl*** cars is that the doors are made in 2 pieces, an inner and an outer. At the factory they put the gl*** in the door and put all the mechanicals in and then they put the inner piece together. Tough to change a gl*** and really impossible to change the door latch without doing some damage. Im finishing a 34 outlaw coupe now and have had very little problems with the car just some aftermarket parts. If you are trying to put the gl*** in make a wedge of wood and force it into the opening enough to get clearance for the gl***. If its the motor or brackets then find someone with small hands to help you get inside to tighten bolts. Hope this helps RED Good luck with the car.
  19. Junior Stock
    Junior Stock
    So what questions do you have?
  20. panhead1961
    panhead1961
    Thanks guys... good info Red!
    I was able to get the gl*** down in the door but had to cut access holes to get the felt channel in the metal tracks. The felt I had was a little wide and a ***** to get in the metal channel. I ordered a different size but not sure it will bend at the top of the frame. May have to notch it to make the curves. If the new felt works I think I can get the motor in the door will have to take the track and motor apart and re***emble in side the door.
    Fitting the dash on today, tried the garnish mldg, can't figure how it will ever work. Starting to think someone in the owner chain bought something other than Outlaw mldg.
  21. brigrat
    brigrat
    from Wa.St.
    Spent more time redoing, cutting and splicing the Willy's front and rear window moldings than I did building the motor and that's not exaggerating...........
  22. panhead1961
    panhead1961
    Was that an Outlaw car? I had a buddy that bought an A and C Willys and he had very little issues with it.
  23. brigrat
    brigrat
    from Wa.St.
    Outlaw Willys body's #24 & #25.....................
  24. panhead1961
    panhead1961
    Wow...that's the first time I've heard anything like that about Outlaw. Guess all of them will have issues at some time or other.
  25. Hitchhiker
    Hitchhiker
    I tell people to buy gl***...Leaves more steel for me....:rolleyes:
  26. panhead1961
    panhead1961
    Hey Hitch..I hear ya! I've had lots of steel but to be honest I got soooo tired of cutting rust and patching this and that. Thought I would go gl*** for a while.
    Love steel cars tho
  27. Hitchhiker
    Hitchhiker
    There is nothing wrong with gl*** either. I'm not hating. Just being a smart ***....
  28. Lytles Garage
    Lytles Garage
    25-30 years??
  29. Tom Bennett
    Tom Bennett
    I just bought an Outlaw car and I have a lot of questions also. Is there an Outlaw Performance car club or some kind of blog where I can connect with other owners?
  30. Tom Bennett
    Tom Bennett
    Hey Red,
    I recently purchased a 34 Chevy sedan and I was wondering if you had any information on how the car is built? Little by little I’m getting the body back in-line. The biggest problem I’m having is how to get the hood off? I installed new pins, but I cannot figure out how to get the hinges far enough apart to remove the hood.
    Thank you,
    Tom Bennett
    3009 Red Bark Drive
    Conway, SC 29526
    215-858-7110
