1932 Ford 2dr. Sedan Window Heights?
Discussion in 'The Hokey Ass Message Board' started by 70kid, Feb 9, 2013.
  1. 70kid
    70kid
    from Denver
    To all,
    I am looking for stock window heights (6), for a 32' two door sedan.
    If anyone has an original sedan or any technical sheets on the matter
    that would be greatly appreciated.
    Thanks!
  2. luxobarge
    luxobarge
    from SoCal
    If you mean the height of the openings, the doors and quarters are 13-5/8" and the rear is 9" in approx the middle of the windows. If you mean the actual gl*** I do not know. Mine are installed, too hard to get a measurement.
  3. 70kid
    70kid
    from Denver
    luxobarge-
    Thanks alot, that wil definately speed things up,
    would you happen to know the front as well?
  4. deucemanab
    deucemanab
    I have a stock height 32 sedan.draw me a picture of exactly what you want. cobramanab@flash.net e-mail deucemanab
  5. the metalsurgeon
    the metalsurgeon
    from Denver
    sketch of the dimensions we need.Any help greatly appreciated.
  6. the metalsurgeon
    the metalsurgeon
    from Denver
  7. HOTRODPRIMER
    HOTRODPRIMER
    I have the windshield frame here in the house and it measures 12 1/2" in the center outside edge to outside edge. HRP
  8. the metalsurgeon
    the metalsurgeon
    from Denver
    thank you!
  9. the metalsurgeon
    the metalsurgeon
    from Denver
  10. Deucedreamer
    Deucedreamer
    from BC Canada
    My Tudor isn't at my house right now, it's at my parent's place. I am going there tomorrow. If you still need the measurements, I can get them then. Let me know if you still need them.
  11. 70kid
    70kid
    from Denver
  12. Deucedreamer
    Deucedreamer
    from BC Canada
    What is the "C" measurement in the diagram attached to post #5?
  13. clem
    clem
    unsure how accurate these measurements need to be, but bear in mind that they may vary slightly from car to car depending on where they were built, and if the windsreen (windsheild- to some) is a reproduction one the variance could be substantial -(from experience- over an inch)
  14. Deucedreamer
    Deucedreamer
    from BC Canada
    So today I had a chance to see my Tudor sedan. I took the measurements you requested, with the exception of C since I didn't understand what C was. They are as follows:
    A: 13.5"
    B: 13 7/8"
    D: 9 1/8"
    These were measured in the middle of the window from top to bottom, not taking into account any window rubber or felt etc. Hope this helps.
  15. 70kid
    70kid
    from Denver
    Thanks Duecedreamer, I believe C was the front
    much appreciated
