Upholstery guys, hidden fasteners?
Discussion in 'The Hokey Ass Message Board' started by wayfarer, Feb 9, 2013.
  1. wayfarer
    wayfarer
    I have a '53 Chevy wagon that I'm trying to get on the road this year. Eventually, I'd like to wood grain the outside, but for now I'd like to build some wooden door panels for the interior. Are there any upholstery clips that would work for this without showing on the face, or should I just neatly attach them with those chrome upholstery screws?
  2. upspirate
    upspirate
    Velcro would be one option
  3. HOTRODPRIMER
    HOTRODPRIMER
    If there is one that doesn't show I'm not aware of it. HRP
  4. wbrw32
    wbrw32
    yes.There are many clips available for attaching door panels without them showing from the front...AU-VE-CO is the mfg...find yourself a good auto uphol supply and they should have them...the chrome screws just look like an after thought in my opinion
  5. HOTRODPRIMER
    HOTRODPRIMER
    Do you have a photo of a fastener that you can use on the back of wooden door panel and it not show?
    I take it he doesn't intend to cover the wood. HRP
  6. Doctor Detroit
    Doctor Detroit
    Do a search for magnetic fasteners. They are usually two pieces. I think a company called magdaddy makes them.
  7. shmoozo
    shmoozo
    from Media, PA
    I found their catalog online. What a selection of fasteners!
    Auto-Vehicle Parts Co.
  8. 56premiere
    56premiere
    If you are not covering the wood Velcro or magnet.Still might need a couple of screws to keep it solid.Covering it will provide many options.
  9. tbill
    tbill
    from central ny
    depending on how thick the material is, couldn't you cut a slot in the back side and use modern type 'Christmas tree' plastic retainers like current cars use?
  10. desotot
    desotot
    You will probably destroy the panels when removing them in the future but many small dabs of windshield urethane might work depending on the humidity in your area, because that would make your panels expand and contract, the reason door panels work well is that they allow a panel to do this but of course they would show.
  11. falcongeorge
    falcongeorge
    from BC
    Solid gold. Added to my favorites.
  12. Marcel8u
    Marcel8u
    You can counter sink the screws then plug them with wood plugs sand them smooth but you will not be able to take off door panel easily.
  13. 63 Avanti 3137
    63 Avanti 3137
    FYI: I just came across them a few weeks ago and went through a bit trying to figure out how to get something... basically call the 800 # and ask for a distributor in your area and try to connect with them. The catalog/download is a great source for diagrams of the parts and some cross referencing of part #'s when your trying to match something up, but you need someone else to order it for you.
  14. ago
    ago
    from pgh. pa.
    How about Phillips screws with the washer ring around them that shows on the outside. You will see the screw but if chrome screws and washers .
    Ago
