55 f100 battery relocation
Discussion in 'The Hokey Ass Message Board' started by kingscc, Feb 10, 2013.
  1. kingscc
    kingscc
    I'm relocating my battery from the floor and I'm looking for some good suggestions on alternatives. I'm thinking of putting it in the fender behind the wheel.
    Thank you for any feedback.
  2. BOHICA
    BOHICA
    Just leave it where it's at. Behind the wheel is a much worse place for it - both in terms of exposure to the elements as well as damage from road debris.
  3. kingscc
    kingscc
    I'm also looking at a spot near the radiator.
  4. CharlieLed
    CharlieLed
    What is your motivation for the move? IMO the stock location is optimal...hidden in a space that is secure from theft and out of the way.
  5. kingscc
    kingscc
    It is but over the years I've had electrical issues of many kinds and since I'm rebuilding the truck completely this time I'd like to make it more user friendly,haha. My original plan was to put it in a bed box I was using befor but I don't want to be committed to it if I change my mind. As the project progressed, I filled the space for the battery with other things.
  6. 40Standard
    40Standard
    from Indy
    put it on the p***enger side frame behind the front tire. works out great
  7. mechanickeith
    mechanickeith
    I built a 54 for my boss. He wanted dual side mount fuel tanks, so battery was relocated to the area behind the right front wheel. gell cell turnd on its side. Made a nice aluminum cover for it. Worked fine.
  8. Atwater Mike
    Atwater Mike
    Mechanickieth is right. IF you must locate it there, build a box for it. The area of location is ideal, as it shortens the distance to the starter via the cable.
  9. coupe man
    coupe man
    Any body remove the gas tank from the cab and mount the battery behind the seat.Will it fit.
  10. kingscc
    kingscc
    I looked at putting it behind the seat but there's only 7inches and I'm not sure there's enough room. I was planning on building a box if I put it behind the wheel.
  11. 53 effie
    53 effie
    The gas tank isn't inside the cab on a '55 F-100. It's underneath on the left side outside the frame. There's nothing behind the seat except the gas tank filler going through..
    I left the battery in the stock location on my '53. Many got moved to under the hood years ago and mine was there when I got. While it is a bit of a pain to access it, I like it better in the stock location. The cables aren't that much longer than any other car.
  12. kingscc
    kingscc
    My 55 was stock in that respect yes, but the space behind the seat will be the same when the gas tank is removed from a 56.
  13. dorf
    dorf
    from ohio
    i have seen where they cut a hole in the inner fender behind the radiator support on the right side and weld a box in . i think that is the way iam going with mine
  14. no55mad
    no55mad
    Can I have your old original tray that the battery sits on.
  15. kingscc
    kingscc
    Unfortunately the battery tray was completely rotted out. I've seen them on eBay for around thirty bucks.
