Frame Identification / 32- 5 window coupe finds me!
Discussion in 'The Hokey Ass Message Board' started by kracker36, Feb 9, 2013.
  1. kracker36
    kracker36
    I found---lets say a desirable body today. The owner sent me a pic of this frame later and I really cant figure out exactly what it is. Any ideas guys?
  2. mastergun1980
    mastergun1980
    from Alva OK
    Some side view pictures ( or any picture showing a little more ) would help but looks 32-34 ford to me
  3. kracker36
    kracker36
    He only emailed me this pic. I was hoping that it was a 32 frame that was usable.:D
  4. Hotrodbuilderny
    Hotrodbuilderny
    Looks like a truck ch***is
  5. Certainly looks like a 32 Ford, you can just see the left leg of the original K-member.
    Looks like it was under a hay wagon with those extra springs - I've bought two rolling like that in the last year.
  6. metal man
    metal man
    Yep^^^^^. I don't think it was a wagon,though. Still has a fender on it and the steering isn't locked down. There will be some good parts there.
  7. Carter
    Carter
    Yes, 32 Ford, both k member legs are there. The center of the k member looks like it was cut on a bit. Front crossmember looks like it has some major welding on it. Also, looks like the drag link, pitman arm and the right front fender are there. Non stock engine mounts added behind front crossmember too.
    I'd say it was a hot rod at one time, not a wagon.
    Sent from my DROID device using the TJJ mobile app
  8. kracker36
    kracker36
    Just got another pic. Looks like a 32 maybe.
  9. metal man
    metal man
    It is definitely a Deuce frame.
  10. BAD ROD
    BAD ROD
    Did the desirable body come off this frame? :)
  11. kracker36
    kracker36
    Thanks for the help guys. This is really a strange story. Yesterday I was having a 2-post lift installed in my shop. One of the guys installing it looked at some of my cars for a while, and like normal we chatted for a while about them. He really liked my 30 Tudor that my wife bought me last week. While he was on the ladder working, he told me that his grandfather had an old car from the 30s behind his house. He wasnt positive about what it was. He said that parts for it were ****tered over 2 different farms. He is needing a 390 FE engine for a 71 F100 that he had, so I told him that i was interested in the car and that I would help him with his build. Pics are coming in.
  12. kracker36
    kracker36
    All of my fingers are crossed my friend!!
  13. Harms Way
    Harms Way
    Yep,... 32' Ford. Looks like somebody added the Hurst frame mounts for a late model engine (looks like it might have had a Chevy with a front saddle mount, But that is a guess) And the stock "K" member was cut out at the bottom for a different transmission.....
    Keep us posted on this.
  14. chaddilac
    chaddilac
    That's a 49 plymouth bumper!!
  15. kracker36
    kracker36
    Another pic of the frame. Check out the rear set up.
    kidcampbell71 and hipster like this.
  16. satan's childs
    satan's childs
    32 ford frame used to be a old hotrods
  17. timwhit
    timwhit
    Last pictured made it real easy...'32 ford, the fender bolts on like a '32, yep its '32.
  18. kracker36
    kracker36
    Well guys, I waited on pics of the body just to be sure of what it was.
    The body was at a different location and he got them to me today.
    kidcampbell71 likes this.
  19. Carter
    Carter
    Cool, do you have it home yet?:D
  20. gimpyshotrods
    gimpyshotrods
    RUN, don't walk, back and GET IT!
    hipster likes this.
  21. kracker36
    kracker36
    Working on it. Finally got to talk to the grandfather. He ran a 327 3-2's in it for a while and parked it to pull the engine and put it in a 55 Chevy. He got drafted and never moved the 32 after that. Keep your fingers crossed for me guys. Im really excited to have a chance to get a real deal deuce coupe.:D
  22. Ghost28
    Ghost28
    Aww man if that car could talk. I would listen and make notes of everything the grandfather has to say. Here's hoping you get it what a great find.
  23. kracker36
    kracker36
    Im really hoping that he may have a pic of the car when he was driving it.
  24. kracker36
    kracker36
    Its raining like crazy here today, so it looks like it may be later this week before I can go try to get the 32. I cant really get a lot accomplished in my shop for thinking about the car.
    One pic shows that it had blue/white interior. Have any other members even seen a rear leaf spring set up like this on a 32?
  25. kracker36
    kracker36
  26. kracker36
    kracker36
    Interior pic
  27. VoodooTwin
    VoodooTwin
    from Noo Yawk
    Rain = free car wash. Ignore the water, go GET IT!!!!
  28. 3wLarry
    3wLarry
    from Owasso, Ok
    note to self...send kracker36 a Lucky Basturd card...
  29. FritzJr
    FritzJr
    The pitman arm in the first picture is from an F100 steering box.
  30. Don's Hot Rods
    Don's Hot Rods
    from florida
    He or someone else has removed the original spring and rear end and installed later parallel springs and rear end. Some traction bars have been added too. All that will cut off pretty easily.
    Really nice find, and it's amazing this lived behind his garage all these years.
    Don
