Projects What are you doing with your ride in 2013 ?
Discussion in 'The Hokey Ass Message Board' started by Saxxon, Dec 31, 2012.
  1. monkeywrenching
    monkeywrenching
    from maryland
    Well my project is a large pile of parts, ***embly required. My goal is to get the kick up on the frame finished and get to a rolling ch***is by the end of the year. That would include engine and trans mounted. More than likely that's a pipe dream but it's a good smoke. This all depends on the CFO in the household and how much "overtime" I'll have to put in to get the funds. We'll see.
  2. NickJT
    NickJT
    from S.E. PA
    Install a few things Santa got for me: the Detroit Truetrac, SW Wings tach, B&M trans cooler.
    Figure out suspension mods which I suspect will make it handle better, so basically I think this will be different lighter springs. Hopefully I can drop the rear ride height a bit, too.
    After reading the "Art of Headlight location" thread here I have to improve mine.
    I also plan to put a different motor in it (now a ZZ4) since I have a deep compelling need for more than 500 hp and it would be nice if the motor also weighted less, like with aluminum block & heads.
  3. Edsel58a
    Edsel58a
    Installing a new frame and roof on my car. Keeping it simple this year.
  4. kiwi1967
    kiwi1967
    lower gears in the rear,new interior in my 39 coupe and endless tinkering
  5. 29tudor
    29tudor
    ImageUploadedByTJJ1357175022.475458.jpg ImageUploadedByTJJ1357175344.108177.jpg
    Hopefully getting some 10x15 pie crust cheater slicks, 18" 12 spoke spindle mounts and some 6x2 straight linkage. LET ME KNOW IF YOU CAN HELP A FELLOW HAMBER OUT PLEASE!!!!!
  6. 29tudor
    29tudor
    Oh yeah, got Jamco suspension for the rear of my 52 customline to replace my tired original stock **** and blocks. Wish me luck with Jamco! ImageUploadedByTJJ1357175642.559180.jpg
  7. b-bob
    b-bob
    First priority is to cruise down to Puyallup with the Larson family.
    Bill and i are taking our fresh cars for the first time. Both our cars were finished in 2012.
    Last year we had to go in our Ranger pick ups for different reasons.
  8. Fixing the trans so I can try to break it again at the 2013 Meltdown Drags...
  9. jcmarz
    jcmarz
    from Chino, Ca
    paint, paint, paint and paint.
  10. buzz4041
    buzz4041
    from Texas
    Just put a new AC in it. New 11" rotors and big brakes for the trip to LARS in June.
  11. das858
    das858
    Finish our front engine dragster project in time for nostalgia drags in August.
  12. chiro
    chiro
    Get it driveable
  13. txturbo
    txturbo
    wow....this is like commitment....but here goes. Get the 55 driving for LSR. Get the banger motor in the Model A and get it driving by summer.
  14. Work has begun-Paint and interior.
  15. triumph 1
    triumph 1
    Changing from a single 4bbl to three duces, different camshaft, rewiring with cloth covered wire. And hopefully moving the fuel tank from under the seat to under the bed.
  16. rustang
    rustang
    Sand, sand, sand prime... sand, sand, sand prime.... hopefully paint... :)
  17. Plan to install fresh 351W with aluminum heads, 700R4 using adapter plate, and a set of 3.80's in the rear. Have to modify the center crossmember area to do this, and then I'll do some general cleanup in the interior(wiring, sound deadener, upholstery)
    Plan to start next week.
  18. whoisfelix
    whoisfelix
    65 Continental
    A tune up.
    Seriously clean up the engine bay.
    Fix all 4 windows so they actually roll up and down again.
    New tires.
    Drive the hell out of it.
  19. billy zz
    billy zz
    body work
    clean up interior
    skid plate for oil pan
    roadster headers
