TCI mustang 2 clip
Discussion in 'The Hokey Ass Message Board' started by kingscc, Feb 10, 2013.
  1. kingscc
    kingscc
    Does TCI have steering stops built in to there front end clips or is something else needed?
  2. need louvers ?
    need louvers ?
    As far as I know the steering stops are built into the rack on MustangII and Pinto racks.
  3. HOTRODPRIMER
    HOTRODPRIMER
    Here their information,,HRP
    <table border="0" width="100%"><tbody><tr><td width="16%">
    </td> <td width="20%"> Contact Info.
    Office #: 800-984-6259
    Tech #: 855-693-1259
    Fax #: 909-391-1526
    info@totalcostinvolved.com
    </td></tr></tbody></table>
  4. kingscc
    kingscc
    Thank you. It's a fine clip but there not big on giving people a heads up on what they need.
  5. VoodooTwin
    VoodooTwin
    from Noo Yawk
    I dunno about their "clips", but their MII IFS kit that I used in my truck (4 years ago) didnt need anything added to achieve the stops.
  6. gimpyshotrods
    gimpyshotrods
    They are in the rack.
  7. kingscc
    kingscc
    so tech support has no idea why the wheels don't stop. great, thanks. i keep having to send off pictures to people so they can figure out how there own products.
  8. slow4dr
    slow4dr
    from SoCal
    Asking for pictures is the best way to diagnose a problem, PROPERLY. It could be something as simple as a rack extension installed incorrectly or maybe the wrong length extension.
    *just sayin
  9. kingscc
    kingscc
    your right, its just getting old having to explain to people problems on every part i buy design to solve, my problem. just ironic and frustrating.
  10. brigrat
    brigrat
    from Wa.St.
    The rack would be your limiting travel factor. I read your posts and to be honest I still don't know what your problem is, can you elaborate alittle more or better yet alot more?
  11. kingscc
    kingscc
    currently the problem is that my tie rod ends are hitting the A arms and brake hoses on the back side of the tier. basically its turning to far.
  12. brigrat
    brigrat
    from Wa.St.
    Why are your tie rod ends on the same side as your brake hoses?
    Rack in front of crossmember?
    Dropped spindles or?
    Which kit is it and what's it installed on?
  13. kingscc
    kingscc
    i ment that the tie rods hit on the front side and it hits the hoses on the back side, of each wheel. this is installed on a 55 f100.
  14. need louvers ?
    need louvers ?
    Ya, something sounds fishy here...
  15. VoodooTwin
    VoodooTwin
    from Noo Yawk
    Hate to say it, but we need pictures. Mine works just fine.
  16. 68vette
    68vette
    Did you have to cut the ends of the rack off about 3/4 inch in order to get some resemblence of zero camber?
  17. kingscc
    kingscc
    not sure i fallow. i haven't changed anything from what the instructions intended.
  18. brigrat
    brigrat
    from Wa.St.
    Find center of travel on rack, adjust tie rod ends till front tires look some what straight, report back. No pic's? maybe a video? Just kidding.................
  19. gimpyshotrods
    gimpyshotrods
    What is the width of your MII setup, and are you running rack extenders?
